I just had the thought to google once more when the new EU labels for dryers will become necessary, and the regulations have been released a few months back as I found out.
Of course I did my typical back of the napkin math to see where we are and where we need to go.
Some side notes:
Same label design and classes as anything else basically.
Vented dryers are still legal, but only technicly. All dryers need an EEI of 85 or better. The EEI is a metric calculated in a specific way taking into consideration stuff like load size, usage for both full and half loads etc.
But, from now on, for vented dryers at least, cycle time becomes a metric as well - that means you can't run cold air through the load for ever and make that "Eco" drying. And reaching an EEI of 85 is basically impossible for a vented dryer - even for a normal condenser.
The EEI of 85 is equivalent to the new class "E".
That would mean that an 8kg dryer would be allowed to use about 2.3kWh for a full load spun at 1000rpm (60% residual moisture) to reach class E.
There has to be an Eco cycle - just called Eco, similar to Eco 40-60. That is supposed to dry to 0% residual moisture.
Residual moisture after the Eco cycle will now be listed in the spec sheet.
There are new condesation efficency rating clases. I haven't found the actual values as of yet, but any condensation efficency has to be better than 80% and the label shows 4 classes.
I did some calculations for current models and things look rough.
Th best dryer I could find - VZUGs V6000 dryer - reaches an EEI of 50.2, so a C rating.
All Miele dryers woth mentioning reach C. Actually ALL higher efficency dryers I checked reached C, I haven't found a single B class dryer.
And things likes AEGs 9000 series dryers, which are efficent, but not the same as the other A+++ -10% dryers, now land in the same class as them. All C.
Even some of the least efficent heatpump dryers - which are still VERY efficent - are outlawed under the new standard. Given those are older models (like the 7kg A+ Beko models) and you can get cheaper, more efficent models from other manufacturers now, but that's still something to wrap your head around: A heatpump dryer using to much energy to be legal in the future.
Reaching B shouldn't be impossible though - VZug is almost there, just barely missing an EEI of 50.
But getting an A-class dryer honestly seems impossible to me without some MAJOR changes in compressor technology.
A-class would mean an EEI of 43 or better. With a 9kg dryer, the usage would have to be similar to that of the VZug - which is rated at 7kg. Or to put into perspecive: We would have to improve efficency per kg by over 20%!
Curious to see if we'll see anything at IFA this year.
Still some ways out, but honestly, given where we were 20 years ago, this is still incredible.
Some side notes:
