Angel Food Cake, long considered the benchmark of baking prowess, can be problematic. I can't begin to tell you how many Angel Food doughnuts I pulled out of the bottom of the pan before reading James Beard's caution not to over whip the egg whites because folding the dry ingredients into the firmer whites causes them to deflate more in the oven. For a while I had access to duck eggs and the angel cakes were specutacular because of higher protien and lysozyme counts creating stronger structure bonds with sugar holding air pockets. Dark shelled eggs share some of the same properties.
In the blender pulverize
2 cups sugar
Reserve 1 1/2 cups for the egg whites
Combine the remaining
1/2 cup superfine (blendered) sugar
1 1/2 cups cake flour
sift through a fine mesh 4 times and set aside being careful not to pack or remove the aeration from the flour mixture.
In the large bowl of an electric mixer combine
1 1/2 cups egg whites
1 tablespoon lemon juice
1 teaspoon salt
1 1/2 teaspoons cream of tartar
1 teaspoon vanilla
Beat on medium speed until mixture begins to looks smooth and foamy. Slowly sprinkle in
1 1/2 cups superfine (blendered) sugar.
Increase speed to high for 1 minute. Remove from mixer.
Sift flour mixture over whites in 1/4's carefully folding in the flour mixture with over and under folding motions. (You can use a mixer on low if you really know what you're doing. Never turn the bowl to pull the mixture into the beaters but let it pass away while mixing in flour) Working quickly fold the flour into the whites, not worrying amount mixing it perfectly. Some lumps and streaks of flour are fine. Pile the batter into a clean ungreased tube pan (Never, ever for any reason wack a cake pan on the counter to relieve air bubbles! THEY'RE YOUR FRIEND) and bake at 350 degrees for 38 minutes. Remove from oven and carefully invert the tube onto a small bottle or funnel. Let cool for a couple hours. When removing the cake from the pan use a stiff bladed knife or spatula. Send it down to the bottom of the pan and hold it there while slowly turning the cake pan. Avoid sawing up and down motions as they usually tear the side of the cake.
2 cups sugar
1 teaspoon salt
1 teaspoon vanilla
