Kenmore washer feature debut timeline
1955 - 2-speed washers with Delicate cycle (then named "Modern Fabrics").
1957 - Cold water rinse and washer-dryer combo machine.
1958 - Wash 'n' Wear cycle with first version of cool-down sequence (alternating high speed draining and cold water filling on first timer notch and pausing on second notch).
1960 - Multi-fabric cycle selections, "alphabet" cycle settings, Pre-Wash cycle, and automatic dispensers (detergent, bleach, softener).
1964 - 3-speed washers with Extra-Slow Speed, second version of cool-down sequence (low-speed draining followed by simultaneous filling and agitating on first notch; as timer moves to the next notch, agitation stops and filling continues before resuming low agitation when full; process repeats at next two notches).
1965 - Roto-Flex agitator.
1968 - Vari-Flex agitator.
1969 - Soak cycle (As "Enzyme Soak"; 30 minutes maximum).
1971 - "Knit" cycle (What differences did it have with "Delicate"?). "Enzyme Soak" renamed "Pre-Soak".
1974 - Penta-Swirl and Penta-Vane agitators replace the Roto-Flex and Vari-Flex. Extra timer notch for drain phase, reducing the Pre-Soak cycle to 22 minutes.
1976 - Black panels with wood grain top, Dual-Action Agitator, and third version of cool-down sequence (First notch with 45-second high-speed draining followed by pausing; second notch with cold water filling and resuming high-speed agitation). 8 minutes on Delicate cycle is named the Knit cycle (6 minutes or less was Delicate).
1978 - LED electronic button panel.
1981 - Panel font modified; Normal cycle renamed "Cotton/Sturdy".
1986 - Rubber control knobs and Belt-Drivens give way to Direct-Drivens. (Was that when they first did the 'chugga-chugga' agitation?)
Your comments, additions, and corrections are appreciated!
[this post was last edited: 5/9/2016-05:13]
