ultralux88
Well, I don't know if I showed the mounting situation before, but I initially had this Thermador WK disposal mounted with a newer Anaheim "EZ mount", the plastic one, as it was the only mount that fit which I also had 'around da house'. It ran perfectly smooth and normal...
But then the mounting flange I intended to use arrived, a 3 bolt mount flange for a modern Waste King, the rubber mount on the Thermador fit on it fine, and clamped down. But I've noticed I get some additional vibration and noise I didn't before.
I have no idea what this is about! Sometimes it'll run like this:
Pardon the extra background noise... I've made sure its mounted on there straight, not half on the flange, the flange is centered and level in the sink bottom... Is this just how it is?
