I never got to watch it, but I saw the setup a couple of times. They had a shielded room in the basement that they controlled it from. For some things they had a robotic mechanism that could do stuff like scan over a weld, but for others it was a process of set up a shot, run to the control room, take the shot, run back to the assembly hall and set up for the next shot, etc.
There were some really cool things in that part of the center. Next door to that building was a thing called the X-Ray Calibration Facility. It had a huge vacuum chamber that had a tunnel about four feet in diameter coming out of one side. The tunnel went out through the side of the building and extended on stilts outside to another building about 1/4 mile away. The second building was the "source" building where an X-ray or gamma ray source was set up at the far end of the tunnel. This allowed them to simulate X-ray or gamma ray sources in space, for testing spacecraft sensors (e.g., the Chandra X-ray telescope). The whole tunnel was pumped down to a very high vacuum and kept cold with liquid nitrogen. There was a road that ran alongside the tunnel that I used to walk at lunch. Every few hundred feet there was a liquid-nitrogen-powered cryopump and all kinds of plumbing and venting equipment. For some of the tests they did with it, they went through two tanker trucks of liquid nitrogen a day.
