THINNING #7
newvista58
May 9, 2013
342
Northern NJ
READ THROUGHLY PLEASE:
NOTE: This is same as the model seen in the Lana Turner movie "Imitation of Life".
Nice Good Solid Condition- Lacquer finish is fair, and that is only due to the incompetent movers, last used.
I had this for 35 years, but has Not been used, and was in climate controlled storage for the last 14 years. When I did have in my house I used it regularly with no issue. It had never needed any repairs, except for a new cartridge and needle. It may need them again, as I had purchased them 2nd hand.
It does currently need belts for the Record Changer.
Other than that, no one has "monkeyed" with it. Everything is complete & there, is the original manual/pamphlet wit it. NOTE: ANY of these vintage units should NOT be plugged in and turned on. There is a way to bring it up to voltage slowly while monitoring for any smoke, arcing, shorts, etc., otherwise unit can be damaged. This is AS IS. I clearly state this needs proper Service/Repair in order to be put in service again. PICK UP in PORT JERVIS, NY
    2 MB
    2 MB
    2.1 MB
    1.8 MB
    2 MB
    1.8 MB
