This hurts...
bajaespuma
Mar 16, 2006
6,292
Connecticut
I need to empty my basement for remodeling.
Pictures of machines I'm saying goodbye to are below.
If you are interested anything, let me know via my private email asap. I haven't had time to clean them up yet but I decided to post pictures to give them time to find new homes.
IMG_2832.JPGIMG_2831.JPGIMG_2960.JPGIMG_2963.JPGIMG_2966.JPG I am currently getting rid of them in one way or another. There will be more later.
    1.5 MB
Absolutely smashing washer! I love the long soak option, the programmed cycle, the lights, the push-button knobs, 16 minutes of wash time, the knob.
I wish they would make a modern Dependable Care or Direct Drive version of this washer.
Does this washer still have its wiring/cycle diagram?
To get the stuck, screw out of the agitator when you’re standing in front of the machine, just put your left foot in the tub and hold the agitator from turning
Even if you get this throughout the base of a hard time often times the agitator would rust to the shaft. You may also have to use a puller and heat the top of the agitator gently for quite a while before trying to pull it out.
Thanks for the tip John.
Unfortunately, I won't be able to do that myself, because I tore my left leg tendon right above my knee and if performing such washing machine gymnastics damaged the surgical work, my doctor and I wouldn't forgive me. I'll see if I can hoodwink some younger and fitter man (or woman) to give it a shot.
Are you buying?
Just the tech sheet or a copy of it 😉
If you want the whole washer you can have it first. I'd end up transplanting the control panel / electrical over to a direct drive, dependable care or Speed Queen. I love the cycles, sequences and timer but not the drive components. Hence I feel this machine would do better with an experienced collector who can appreciate it as built.
