Gan: No...this is not a lint filter for recirculating water like filter flos.....
Greg and Tom...... of course there is an explanation to this.
Of course with a FL pump prior to a filter, the filter would be of very little use.... and silly...since the filters as you know are meant to protect pump as I also said...
And the explanation could be a pump able to create a suction, an air vacuum able to suck water vertically and have it passing through the filter.....
So not one of those simple pumps....
I thought naturally of it before....and did my researches about..
Reading a blog in spanish about an old style pump for Fagor machine I could read of a guy attempting to fix his "antigua"-"vintage" F-816 Fagor machine that was leaking from the pump.... he probably inverted the hoses, poles or did something wrong and or messed with it.... but what he got was a pump that instead pumping water out was sucking air into the tub....so of course it was a kind of pump able to create a vacuum....
He called it <span id="result_box" class="short_text" lang="en"><span class="hps">asynchronous</span> <span class="hps">pump that might have a meaning for mechanically cultured people...for me it's greek.... all I understand is that the pumps in Fagor machines likely worked this way so here explained the top pump and gravity thing...
Here a link of the Blog..... google translator should work fairly well, otherwise I can give a translation if you trust in my spanish comprehension skills....
http://linea-blanca.yoreparo.com/lavadoras_secadoras/648476_0.html</span></span>
[this post was last edited: 3/11/2013-17:48]
