thor cylinder washer
10220maher
Apr 16, 2009
3
hi i am looking for any info on a thor cylinder washer
i think this from the 1920s. and is it worth restoring or just a good BEER cooler?
GREAT!!
Really we can say a reliable machine to have reached our era LOL
Curious to see it wasing... oh and it's a TLHA look at!!
BYE
Diomede
Well.... that is entirely up to you!!
1. What condition is it in mechanically? Do things turn or is it all seized up?
2. Is everything there, is it complete?
3. What are your plans for it once it's restored? Do you plan to just display it, use it or sell it?
Personally I think it would be cool to have it and use it occasionally. From the photo it doesn't look too bad cosmetically (nothing some Rustolium and paint couldn't fix).
So I say go for it! It's not every day you see an 80+ year old washing machine!
Go for it.
Top loading horizontal access washers are rare as hens' teeth in the US, but with a wringer? Never seen that before. Go for it because it seems unique and may be extremely water efficient.
What a novelty,
Dave
Not As Rare As One Would Think
Thor, Simplex and a host of others made such washing machines for domestic and commercial laundry use. Indeed washers such as these are still sold in some form today for use in the United States.
Such washers are called just that, "washers", one had to do the extracting in an extractor, or as in the case above use a wringer.
Early H-Axis machines such as this were wood inside, then came models with metal inner tubs.
If you look at pictures posted by Sudsman and others of vinage hospital and other commercial laundries, you will see these machines. Most often they were driven by belts attached to a power system (usually steam), that ran much of everything else in the laundry.
Because these tumblers have their bearings on either side, they could be bulit into a wall with openings on each side. This was and still is common practice in hospital and or other commercial laundries that handle "infected" soiled linen. In this manner clean laundry from the machine is not removed nor comes into contact with the "dirty" side of the laundry.
L.
Nice find Mike..
there a number of Mfgs. still making that type of machine. In the US today. Range from 100 to 1200 lbs. They are avail.as washers and washer/extractor combos. Many used in Hospital Laundries just as Launderess stated. In picture is a American 900 lbs with card a matic controls.
Another machine
a 50lb machine very close to what you have Sells for almost 9000.00 they have them in stock.
