norgechef
I just started using Tide washing machine cleaner about a month ago, because my Maytag Atlantis was starting to get gunked up with softener residue in the dispenser and the agitator. Also, my Kenmore HE5T was starting to get a moldy odor which I'm told is normal with these machines. When I looked behind the door boot on my HE5T I noticed a layer of build up which wasn't cleaned away using the directions on the package. I ended up scrubbing it out.
I have a few more observations and some questions. First off, the smell of the cleaner. It is overwhelmingly strong. Like regular Gain detergent x100. I have, at this point used it once a week, for 3 consecutive weeks as it says to do on the package, and I have mixed feelings.
With the Atlantis it did remove the softener build up, the agitator bolt still looks a little sludgy though. Not sure what I would use to clean that. I add 2 packets of the cleaner instead of one because it uses so much more water than a front loader, and I knew the only way the softener dispenser was getting clean was if it was submerged in water, so I just threw it in during the cleaning cycles and it is spotless. However, after the cleaning cycles, it always seems to leave a thick, strong smelling residue on the agitator. It is not visible but it is sticky. That was not there before running these cleaning cycles. Also, the pump failed during the last few days. Which is common with ''Norgetag'' pumps. Probably unrelated, but I found it odd.
On the Kenmore it doesn't seem to do much, even using it on the sanitary cycle. It smells better, but the residue inside the boot seal never came off, so that makes me question whether its really cleaning the other parts inside the tub. It seems to do nothing more than cover up the moldy odor with the offensively strong scent.
Do any of you use Tide washing machine cleaner? Does anyone prefer it over Affresh or using bleach? I know the Tide can't be used on the cleaning cycle for the Kenmore but maybe the Affresh can. It's been years since I've used anything but bleach in the Kenmore, because the cleaning cycle says to use bleach only and bleach with detergent as it says to use in the Maytag manual. But I was finding it was not working so well. That's when I tried the Tide. I think I'll try Affresh next, and maybe alternate between them if I don't find a difference. What is the best option for odor and reside removal in your opinion?
