Today's POD - 1967 Kenmore literature
kenmoreguy64
Jan 30, 2008
3,282
Charlotte, NC
This and one other occasional POD of service literature from the 1967 Kenmore line I find fascinating.
Not only do I love the one-knob wonders in this picture, some of them are not considered fully automatic washers!!! Also interesting, the model numbers shown are wrong. The 110.6703xxx numbers are for the semi-automatics (which you have to select temps at the faucets). The 110.6704xxx numbers are the automatics.
Still, I LOVE looking at this list, and would enjoy finding one of the 29-inch one-knob machines. It would be fun to photo-shop the correct model numbers to the pictures!
We always seem to enjoy the POD, so thanks again Robert!!
Gordon
I think you would still consider them fully automatic though. Kenmore did make a model at one time that was full size and called a semi-automatic. You would wheel it to the sink, fill it with a hose, set the timer to agitate, than set it to drain into the sink, then to spin and repeat for rinse. I believe it was called a Swirl-away? My grandmother's only automatic was an old one dial Kenmore that did say Automatic Washer on the name plate. You had to use a Y adapter for the inlet hoses as it only had one inlet opening on the machine. So by turning both hot and cold faucets you would adjust the water temperature. You could adjust the water level by advancing the timer to around 4 minutes and it would atart agitating at that level.
of the model versions....it states most have a 6 vane agitator.....would that be the Roto-Swirl......even in the BOL?, I would have expected the 3 straight vane, interesting....
Kenmore considers the 110.6703xxx models as separate, or different from the true automatics. If not, they wouldn't have different model numbers. If the user has to manually manipulate faucets to select temperatures, that kills off one of the criteria they used early on when calling a machine an "Automatic washer". Up through 1973, Kenmore's model numbers were of this format:
110.6703xxx - "semi" automatics, OR maybe better called single valve automatics
110.6704xxx - autos (and 110.6714xxx)
110.6705xxx - auto suds models
110.6702xxx - were wringers I believe.
The first two digits to the right of the decimal indicate the model year. True, the -03 machines operate a full cycle on their own, but they require more from user interface or control, especially for rinse temps than the true automatics with the dual or triple solenoid inlet valves. Each of the -03 machines have a single solenoid inlet valve.
Looks like these didn't last much longer. There were a few 1968 models, no 1969s, and then a couple in 1970. I couldn't find any on Sears' site newer than those.
Gordon
But why did the front say Automatic Washer on it? Guess they were not telling the truth on the nameplate. I always thought if you turn it on and pretty much could forget it until the load was finished, it was automatic. Unless you wanted to watch it with the lid open (but remember kids, dont touch it). Ya right, as soon as nobodys looking.
You know what.....I think we were all super children.....way too smart not to put our hand in there while it was running......used my Grandmother's cane to push clothes down, stood on a chair to watch all the action.....that washer was my babysitter, I would never leave it during the entire wash day, and you couldn't drag me away for nothing......they always knew exactly were I was at......Now, as an adult, about 20, I pushed the clothes down one time by hand, and the agitator caught my thumbnail, and ripped it off.....less common sense as I got older...
odd enough for my Mother, when she shopped at Sears, left me at the washers, especially the one with the glass tub with the plastic rings showing the wash action.....I wasn't going anywhere!!!.....and was there when she was ready to go......never a threat of being abducted....nobody was taking me from that....lol....if they only thought, hang a washer from a string to lure me outside!!!...
I'm guessing, even with the timer alone, it could perform only one function at a time, it was Automatic because it could do this by itself....as opposed to a wringer needed full attention of the operator....
Ha, Ha
I remember the poker chips running in the clear Visimatic in my local Sears. (when nobody was looking) I would switch it from slow to high agitation and hide in the TV section. The manager of that department was a good friend of the family. I bought a Kenmore dishwasher from him many years later and he laughed and told me they all got a kick out of watching me knowing how to switch low to high.
