Toggle's Appliances
Toggle's Appliances
GE gas dryer
Notice that the location of the lint filter has migrated to have a front opening rather than a top opening.
Supposed to prevent lint from getting on dry garmetns as they are removed.
Baby, just lick your fingers, rub along the surface (not shown)and you get results. No need to handle the whole thing.
Interesting also that the drum looks purple. nto so in reality. I wonder if the camera is picking up discoloration of SS due to heat, that is not visible to naked eye.
Toggle's Appliances
Oil -fired steam heat and domestic hot water plant.
Burnham Brand boiler
Riello brand burner head.
Left in black= oil filter.
beige, (bottom-left)= circulator to push (non-potable)hot water to basement heating loop via baeboard style convectors ("radiators").
You can also see the Hartford Loop made of 2" wide steel threaded pipe that goes up across and then down This it to keep the water in the boier in case of slight over-fill and when the steam is fresh and not yet dry (superheated). As the steam becomes "dry" it rises and flows by gravity to the radiators.
Green boxes (left side) relay for low-votlage control (24v). One is to control the burner the other is to control the circulator -- allows for a 24v thermostat.
Green round valve (left-side near top.) Thermostatic mixing valve (non-electric) cools water to safe temp by introducing cold to hot water feed line.
Between red valves is water-level viewing gauge. In a steam boiler the water level i partially full, in a hot water boiler it is entirely full.
Left of red valves is water level sensor that---
a) adds water by shooting a signal to the black box back-right (trace the wires).
b) turns off heat should boiler run dry.
Even further left of that is the pressure-limit control switchover a pipe pig-tail. shuts off burner when system is pressureized. cycles burner on and off as home is being heated.
Shoulf that control fail, there is a mechanical pressure relief vavlve above that. It prevents explosions due to steam build-up.
Domestic hot water needs are met by a coil on the right side.
You can see the grey thermostat (aquastat) that maintains the minimum boiler temp, when steam is not needed.
Toggle's Appliances
WP electric smooth-top 30" self-clean ["pyrolytic" for you Brits :-)] range TOL (or near TOL).
S M L burners and the L one switches to 110v as a "simmer" element.
Half price. Slight mar on left side..invisible to me here.
AVANTI (Turkish) 20" gas stove with sealed burner and waist-high broiler ("Grill" => UK) oven can be used if there is no power for ignitor.. WOOOO-HOOO
Toggle's Appliances
ref- boring
Kenmore badged Amana by Maytag...LOL
bottom mount- (means freezer is on the bottom)
I like it like that!
Side door (now) behind fridge recently sealed-over. Needs to be painted. Meaning we moved the fridge, LOL not the door. LOL
Toggle's Appliances
RCA wall A/C by GE.
Noisy as hell. A gift (used) from the mother -in-law. One day that moulding will get painted. LOL
Dont use it much since central air was installed.
So there we are, thanks for joining me!
