twintubber
Ok, so I'm gonna try this again.
Hi everyone.
So, the last KitchenAid experience didn't work out too well.
But this time, I think it's gonna work out all right.
I've been talking to the seller since the weekend and he's holding it for me.
I was supposed to go and get it tonight, but my ride fell through and so we're off to do it "Tomorrow". Yes, I'm an ANNIE fan!!!
It's a WhirlAid version, so I can now have a "set" of KA's in both it's best inceptions-the last of the true Hobart machines and the better of the Whirlpool made versions.
From what I can make out by my brochures it is a 1995-96 model and it should be model #-YKUDS230BW and it's in excellent condition according to the ad AND the pics show that to be quite true.
I plan to make this incoming one my main unit and use the 19 as my plastics machine. And even though it's white, I can still change the front panels to black and only the control panel will have to be white.
The Bosch hasn't been used since I got the 19, since I like it better and it's much more fun to use, so it will be nice to fully use two dishwashers again. I'll use the WhirlAid as the main unit because it has superior filtration and the racks are better for those kinds of loads that the main unit handles.
And even though the 22 that I got a few months ago doesn't work, the upper spray arm from it is definitely giving better results in the 19 and the insulation blanket from it has really quieted the 19 tremendously! Not to mention the energy efficiency it adds to it. So I got some good out of it for my 80 bucks. That unusable machine I bought a few months ago though is not quite the same pump design, so not all the parts will be compatible, but I plan to break it down and keep some of it for parts.
I figure the motor, timer, detergent dispenser and the rinse aid dispenser should be enough since the racks are completely toast and the fill valve is shot. And I already switched out the upper spray arm to use in the 19. The 4-Way Hydro-Sweep wash arm will not be salvageable though as all three machines have different designs of the arm and are therefore not interchangeable.
So, the two pics that were posted are attached and I'll try to post the actual link to the ad, even though I'm not sure I know how still.
http://[email protected]
Hi everyone.
