The title of this thread is a bit too generic because grouping an LG or Samsung Front Loading washer and a vintage Westinghouse FL in the same category doesn’t really work. The same goes with comparing a modern base impeller top-loading washer with a Frigidaire Unimatic or a vintage Whirlpool belt-drive TL, it just doesn’t work.
So about two months I was given this 2007 LG washer. The door hinge was frozen in the open position due to corrosion from a leak in the boot. If fixed the leak and took the door hinge apart and greased it and now it works perfectly. So after using the Unimatic almost exclusively for a few months, I have now used the LG nearly exclusively as it was designed without making any mechanical adjustments for over a month and here is my personal opinion…
For washing ability I’d say it is excellent. It seems to clean well and remove stains from things. You only need about 1/8 to 1/4 of the detergent that I use in my vintage machines although for me personally I couldn’t care less about the amount of detergent I use, whatever works best for each machine I’m fine with.
Rinsing is another story. I see a lot of people calming that these new front loaders are rinsing better but in my opinion this has not my experience. I always use the extra rinse option (so three rinses total in the LG) along with the “water plus” feature. While it seems to rinse okay, what I’ve noticed is sheets still have quite a bit of detergent smell for two to three days after putting them back on the bed. With most of my vintage machines this is not the case using the same Tide detergent, but more of it in the vintage machines. When I put sheets back on the bed there is little to no smell of detergent what so ever out of the vintage machines, especially the solid tubs. I have huge newish Turkish bath sheet white towels. I always use bleach on these and I can clearly smell bleach on the towels when I remove them from the LG. I never smell bleach when I remove those towels from the Unimatic where I normally wash them. I use 1/4 cup of bleach in the LG and 3/4 of a cup in the Unimatic bleach dispenser. Another big difference I noticed is the towels are slightly less soft when washed in the LG than they are out of the Unimatic. I’m not sure if that is attributed to rinsing ability or not, but I suspect it is. I don’t use fabric softener in towels that are less than a year old.
Water extraction seems really good, I use extra high speed spin for nearly everything. I’ve been drying most loads in the Wards gas dryer which has a very accurate auto-dry cycle. Loads of 4 large bath sheets towels are drying in nearly the same time (about 25 to 27 minutes) as the Unimatic or GE AW6, both with 1140rpm spin. Those same towels take 35 to 40 minutes to dry in the Wards dryer from my vintage machines that spin below 700 rpm.
As for overall gentleness I’m not quite sure and need more time to experiment. I did notice after a month of using the LG the back pockets of my Diesel jeans were starting to fray slightly. I don’t know if that would have happened anyway using any of my other machines, but the Diesel jeans that I wear generally last a long time. I’m not convinced that the smack action of tumbling those clothes in a small pool of water with a large vertical fall for 40 to 45 minutes overall between wash and rinses is all that gentle, then tumbling again in the dryer.
Dryer lint seems slightly less out of the LG about on par with my non-back and forth style agitator washers. Back and forth agitation seems to produce the most linting. However the difference overall is not all that much.
So Phil is right, I’m not convinced that this method is superior for overall results. However the savings in water is significant which is good that the general population is heading in that direction.
Overall I’d say it is an excellent washer for the masses. Most people unless they are allergic will never notice the difference between properly rinsed and just okay rinsed clothes. I did have a GE Harmony washer a while back and was not at all impressed with that machine, I thought it was way rough on the clothes unless you forced it to fill all the way up. If I had to choose between a modern front loader and a modern top loader for sure I would pick the modern front loader. Thankfully however I don’t have to make that choice.
