Top Loader Extra Rinse?
curious as to what causes one machine to rinse better than another....
maybe...
timing of when spin/spray starts, and for how long?
spin speed and time once full speed is acquired?
fabric, like towels, that hold a lot more suds?
machines that don't have a one-way valve on the pump, allowing remaining suds from wash, to be pumped back into the machine during rinse...
also machines like a DD Kenmore....those pumps spinning backwards during agitation can whip up a lather of suds on their own...
oddly enough, spin/spray rinsing...like on the Eco cycle and machines like the Cabrio have been shown to be very effective...
but that could be an idea from their FL counterpart machines....rinsing is nothing more than saturate, and extract several times.....just like if you handwashed an item in the sink...
It seems to me that there would be a trade off in the amount of detergent used vs. how clean very dirty loads would turn out. I've washed some kind of nasty that required more detergent, which produced more suds that required 2 or 3 rinses to get the rinse water to acceptable level. Towels often need hot water bleach, and more soap to cut the body oils.
I called SQ on the detergent issue when I bought my machine, as I was reading conflicting advice. I read that powdered detergents was rough on the pump and cause it to wear out through abrasion. I read that liquid detergents caused the pump to "gum" up and thus wear out. The rep. I spoke to recommended to "use only a drizzle" of soap. Now to me, "a drizzle" would indicate a liquid. So I used less soap, to cut the froth, and cut out the 2nd rinse on most loads. Towels, however, are a lost cause. The rinse water in the 2nd rinse is very, very cloudy and many times still has suds. It's hard to justify a 3rd rinse, due to water usage the Queen uses. Have found that certain detergents are HORRIBLE with this machine.
A trip to the Dr. confirmed what I suspected in the rinsing abilities of SQ. Learned the hard way.
Told myself I wasn't going to reply on this thread!!! LOL.
Barry
I'm Having No Problem
with rinsing in this new 432. None. I started this thread out of curiosity re top loaders. I'm not having excessive detergent left in any laundry--and that includes towels. I always use white vinegar in every load in the fabric softener cup and I think that helps. I always use Borax. As with my front loaders, the only time I pick extra rinse is if I have particularly dirty or soiled things, like when I wash my cat's beds. For that, I also use the Lysol brand washer disinfectant and it works perfectly, too.
Sad that so many are having problems I'm not--perhaps it's the water--or the phase of the moon...
Martin said: "curious as to what causes one machine to rinse better than another...." and then listed a number of good reasons why some machines rinse better than others.
Another reason for poor rinses are how the water spray enters the tub -- for machines designed to do an eco-spray rinse, the water is often directed in a very wide fan-like pattern and midway between the agitator and the clothes, so the spray fully distributes and rinses equally well no matter where your clothes are.
The "original" Amana/SpeedQueen from the 90's didn't do that -- it had a "self-cleaning" "filter" a la rim-flo (like the Hotpoint), but unlike the Hotpoint washers, the water jet would fall inside the filter and mostly be directed outside the basket with just a tiny bit passing thru the filter and reaching the inside of the basket. Of course, once the spinning started, the piddling amount of water that actually was directed to inside the basket would be deflected by the air and the spinning motion and just rinse the top few inches of clothing.
In fact, an experiment I would frequently run to show friends where the water hit, is to fill the washer basket with a load of towels, start the machine at the spin rinse portion, and turn it off before it starts filling for the deep rinse. See which towels are dry and which ones are damp. Some machines will only spray rinse the lower few inches of clothing, some only the top few inches. Ideally, all the towels would be equally damp if the spray rinse was effective.
Another test, a bit more fair, is to wash a load of towels with hot water, let the cycle progress a bit after the spin rinse but stop it before it starts filling for the deep rinse. See which towels are still hot (very little rinsing), which towels are warm or cold (better rinsing). The rinsing pattern for this test is often different from the first one because of the way the clothes settle when the machine drains (neutral or spin), and the combination of detergent and water alters a bit how the rinse water filters thru the clothes on the way to the basket walls.
A fascinating test, which most places do not have the lab equipment to do, but you can often see it in Universities that study fluid dynamics -- the washer is either fed with washable dye for the wash and then the spin rinse is regular water or the reverse, spin rinse with tinted water to see the dye distribution on the clothes.
In any case, seeing is believing -- toploaders, as a class, do not rinse well, and the ones that do have a much better spray rinse than the others. Frontloaders dilute the dye solution out of the clothes much faster and with less water. The key here is not exactly how you agitate the load (top vs. front-loader), but the fact that if you saturate the clothes and then drain or spin them and do that multiple times you dilute and get rid of the "wash solution" (or dye, in this case) faster than only one or even two deep rinses. This is the reason that a good spin rinse and a deep rinse were enough for older toploaders, but most of them made in recent times went straight from wash to spin to deep rinse, which is not ideal. You want to remove way more detergent before the fabric softener or vinegar hits the clothes in the rinse. Toploaders with a decent spray rinse (recirculated, and several distinct spray rinses which drain and repeat with fresh water) can rinse very effectively too, but most toploaders did not do that and I haven't keep current with the market to know if the newer ones have changed. But the system is pretty old, Fisher&Paykel washers did this I think 20 years ago, there were a few models like the WP Resource Saver and Calypso, and I think, if I got the descriptions right, maybe the newer Speed Queens are doing something similar? Not sure.
Cheers,
   -- Paulo.
