This topic has come up before but I cannot find the thread.
Previously there was a discussion about pets and appliances, particularly pets turning on smoothtop ranges equipped with knob-less touch-control. I am particularly sensitive to this subject as I am a CFEI and worked for a company that made electric ranges. I was involved with product safety.
We do own a smoothtop range with touch-control. In the past, I DID see with my own two eyes, our cat jump on the counter and sit down on the unlock button. The cat actually was able to unlock the range. When the range beeped, it startled the cat who then walked onto the burner button, activating that too. The burner did not turn on as one has to touch the burner button once more. I removed the cat before he could start the range.
I came up with my own remedy. Will explain that later.
Then came the reports of a hundred or more house fires in Korea due to cats turning on ranges equipped with touch-control. Very concerning.
Well, the other day I went over to my late MIL’s house to check in. A cousin, and retired fireman is moving in. He has two cats.
He pulled me over and asked what to do as the cat had unlocked the smoothtop range. They own a different brand than I. Our two range brands are not related and are from two wildly different manufacturers.
He observed the cat putting its paw on the unlock button and the range unlocked. I went over to the range and put my finger on the unlock pad. The range unlocked rather quickly.
We experimented with his range to see what would unlock it. He picked up a metal saucepan by the handle and touched it to the unlock pad. The range quickly unlocked.
And so it appears that in some ranges (his and mine) you don’t need a warm finger to unlock the range, just merely present some CHANGE to the unlock pad / button. I don’t know if the smoothtop is designed to detect a change in temperature or capacitance.
So today I decide to make bacon in my Westinghouse Baconer. I plug the Baconer far down the counter but mindlessly placed the plastic package of cold bacon on the range top. BEEP BEEP BEEP and the range is unlocked using cold bacon.
Experimented some more. I could unlock the range with a metal spoon. Again, I am unsure whether it is a capacitive or temperature change which is triggering the unlock function.
… And so I write this dissertation for this reason. Many people think that pressure on the unlock pad by a warm finger is the only way to unlock a touch-control range. With at least our two brands this appears to not be true. In our experience, an ABRUPT CHANGE presented to the unlock pad is what unlocks it.
Unfortunately I do not have the schematics for either range so I cannot definitively tell.
My remedy for the range was sort-of two-fold. We actually had two ranges. The first range was rather easily tripped by the cat. I came up with a cover for the touch-control pads. It worked. However I will not mention here what I used as I think it was not the best idea after all even though it did work.
The first smoothtop range failed and we replaced it with the same brand but newer model. This one is more resistant to unlocking so I don’t feel the need to cover the touch pads.
I suggested to my cousin that he concocts a cover for his touch pads but one that doesn’t touch the pads at all. He’s a very good tech and seemed to understand the value of doing so. He is also considering putting a circuit-breaker under the counter to kill power when the range is unused.
In my case, I now pull the breaker to the range when on vacation. It will likely be the last touch-control range I buy.
Whew! Comments and questions welcome.
