toughs on new duet washer from whirlpool?
These are not actually duets or they are not called that anymore. This looks like the WFW6620 that I currently own.
Very good machine. Very water and energy efficient and a great cleaner. Nice assortment of cycles and features. Highly recommend.
agiflow do you think if for x reason my mom and i had to replace or current set i should reccomend those to my mom? and that comes to my other question what are the water temp and how long can the drying time for the dryer be set if load needs a shorter drying time exemple a small load and do the washer have a light inside if washer is install in a space where there not much light? i apoligize for all my questions
Hi Pierre. As far as water temps are concerned I never measured the temps but the lowest model with a heater is the WFW5620. If you get a Whirlpool make sure it has a sanitize setting.....DO NOT get one that has the setting "sanitize with oxi"...just "sanitize"....these washers are incredibly water miserly but they do have recirculation pumps.
My drying time for a large load of mixed fabrics I found to be dry within 25-30 minutes.
The WFW6620 has high speed interim spins also. Though I don't think it is the full 1160 rpms. Not sure.
Interim Spins?
Previous generation machines wouldn't spin between rinses during the normal cycle. Does the current generation spin between rinses?
That's something I really don't like about WP, MT and Elecrolux FL'ers. I feel like rinsing is inadequate.
My 9 year old Duet spins in-between wash and rinses on all cycles except delicate or handwash.  If a current machine didn't do interim spins on Normal Cycle, I'd never use it anyway.  That's why they call it Normal, people are too stupid to know what goes on in their washers and complain about poor rinsing.  I use cycles for what I expect them to do, not what the label tells me.
On the normal cycle it will spin between the wash and the first rents but just go right into the second rinse
Lack in interim spins
Could also be to shorten cycle times. The previous generation WP/MT washers would do interim spins between all rinses on the heavy duty cycle. I hope it does the same now if you select regular under "what to wash" and heavy duty on "how to wash".
Yes Bob if I did all the different combinations I could probably have found out but as it is now my machine sits off to the side waiting to be picked up
Not to sound slightly off-topic
But how come Whirlpool, Electrolux and GE seem to have switched usefully delicate cycles, like Hand Wash or Silk, in lieu of,say, Active Wear?
The old generation Duets had variety of selection of specialty cycles that could actually benefit some households. I personally use Wool and Hand Wash at least twice a month.
Saw a video of the only Delicate cycle on 600 Series Elux yesterday and was unimpressed. Way too rough for synthetic sweaters, let alone woolen ones.
I love my WP Duets.  I'd like to get these too.  They have the drawer which gives access to the pump clean out and the detergent auto feeder option.
I've also seen these at Lowes as well for like $600
@appnut, so I'm not the only one lol
@agiflow, while FL machines are way more gentle that traditional TL, washing wool and silk takes special precautions - matter of fact, even if you hand wash them in a sink. Lifting wet wool can cause stretching. Tumbling it - felting.
I thought the Load & Go was an insert in the detergent drawer. Haven't GE had SmartDispense before that utilized the pedestal? Old is new again eh
