Trader Joes is an interesting case. The parallels with Aldi are very striking (also, you will often find the same items (generally the German imports) in both places...frozen strudel, for instance). If you think, though, they're quite similar in concept (narrow selection of fast-moving private label grocery items). Interestingly, not as friendly to work for as you might think (check out HRC for score). Their produce is expensive and heavily shrink-wrapped (I rarely buy anything but bananas, cherry tomatoes and sometimes onions). Their fluid dairy is similarly expensive (they seem to not use local dairies but bring it in from quite far away). I think these both differ from TJs in California, which can do better opportunistic buying Everything else is at a minimum interesting, and some things are really phenomenal. Good pun about the proclivities of the employees...the ones near us give off a Shortbus vibe
Whole Foods is OK...the one near us is dire, though; the larger ones are somewhat better. WF in Detroit actually was purchased from a family (it was called Merchant of Vino) who had a 5 yr noncompete...they recently opened up 3 stores called Plum Market which are nicer than WF (and have more of a local vibe)
