Hi,
The Transmission on my Kenmore washer* appears to be all gummed up. I have removed it from the machine and am about to open up the case and survey the situation. If all is well mechanically, I'll simply clean it out and refill it. However, Whirlpool 350572 is SO expensive. Does anybody know exactly what this OEM oil is? What can I use as a substitute? Regular gear lube? What viscosity? Automatic transmission fluid? 30 weight non-detergent motor oil? How about the capacity - 16oz?
Also (forgive the newbie question) do I need to remove that last cam bar before I try to pull the case apart (see photo)?
Thanks very much,
Chris
*My Dad bought this washer new when I was 12 years old!
Thanks very much,
Chris
