Trusty Commercial Maytag just bit the dust. Which SQ washer and drier?
rebar
Member
Oct 7, 2016
16
Iowa
My maytag LAT2300AAE puked its transmission oil 5 years ago but kept on chugging until last night (18 years) when it wouldn't spin and I smelled a burnt belt.
I don't have the time to rebuild my maytag, but will set it aside as a spare machine after I repair/rebuild it later this winter.
I need a new washer and drier NOW (no spare's)and think SQ is a good choice. But which ones?
I want a machine that is easy to work on and rebuild and have read the FL SQ's are better in that respect to the TL. True?
I keep hearing people say to buy the mechanical controlled SQ but the sales man says the difference in cost between mechanical controller/timer and electronic controller replacement is within $5.00. True? And easily replaced?
So knowing that I want a easy to work on SQ and not worried about water usage.. Which SQ washer and drier?
Thanks!
There is NO BETTER WASHER:
Nor has there ever been in the terms of reliability than the SQ FL.  They are also designed to be fixed.  Figure at least double the lifespan than your MT gave.  Just stay away from the mechanical controls as opting for them shortens the warranty by 2 years.
I bought this set and could not be happier.
WK78
Thanks WK78.
Frankly, I don't consider the warranty a decision maker. Because you never hear of any speed queens having a problem within 3-5 years. I think its SQ's attempt to promote the new electronically controlled units.
Iv read the TL washers are not easy to service is why Iv asked this question. Can you comment on the difference servicing the TL compared to the FL? Because Im the type who buys top quality but also values ease of service.
I would go with the FL set if you have the money. I also wouldn't worry about electronic vs mechanical either, just pick the machine with the features you want. As far as servicing the FL machine, I'd say that's the most service friendly front loader you're gonna find short of going with a commercial washer extractor.
Thanks GusHerb.
I have the money.. But I have to be convinced the extra cost is worth it.
As I mentioned. Water consumption isn't a concern for me because I don't use the minimum the city considers my 4 bedroom home should since I live alone. My bill never changes regardless how much water I use..
But your comment about "that's the most service friendly front loader you're gonna find" is heard and noted..
Thanks again.
I'd opt for the electronic controls too, they give more features and add a little sophistication to these machines. And if you are looking at the FL machines, the 'mechanical' control is just a computer with a knob anyhow, only the TL machines had a mechanical clock timer anymore.
A FL machine is much simpler then a TL machine, there is no transmission and the main seal is above the water line. They are worth repairing when and if they fail, the TL machine may be cost prohibitive to repair in the event of a failure.
I won't open the can of worms in wash performance comparison, but I wouldn't buy the TL machine for that reason.
Sold!
WK78 your "TL machines tested to 10,400 laundromat cycles, FL is tested to 25,000 laundromat cycles." just sold me.. Along with all the additional information.
One last question.. Should I consider a stack able configuration? I have barely enough room for side by side, so gaining the additional space would be nice but not mandatory.
Thanks everyone!
I'm curious as to where Speed Queen states that they test FL washers to 25,000 loads. On their website the longevity calculator is based on 10400 loads just like the TL. That's very close to what we see in laundromat life. But I don't think it's fair to compare home use to laundromat use. Constantly over suds and you wouldn't believe what some people try to wash. Performance is great on the coin op machines. Never used a home machine but I'm sure it's very much the same.
I think I will skip the stackable.
I think I will skip the stack able. I dont want one unit and I envisioned being able to separate them.
A front load machine with it's concentrated detergent during wash and the extended cycle times will all but eliminate the need for pre-soaking. And you get lots of other advantages too.
I am an authorized speed queen dealer and servicer
The electronic controls will never fail. In fact, I would bet the electric controls will outlast any mechanical timer. The front load is probably the most reliable unit you can buy today. There are only a few parts:
Central control (main computer)
Mcu (motor control)
Motor, 3 phase brushless
Water pump
Door lock
Inlet valve
Rear trunnion.
Couple other odds and ends like an off balance switch and such. Everything is front service, in exception to the trunnion, or rear bearing.
The only time I have ever serviced a front loader was a 10 year old unit that ran 8-10 loads per day, 7 days a week at a hair salon. It needed a trunnion, it took me about 1.5 hours to fix. Next time I do it I'll likely get it done in half the time.
My only slight gripe is that I feel like the washing performance could be better. It's not even a mechanical issue, I think if they tweak the wash cycle program it could really be a knock out.
Ps, I own both top and front load speed queens, the front load is my favorite all the way around.
The stacked set comes apart for delivery and service. It is pretty neat how they are built together. I really wish speed queen would have shared power between the dryer and washer, but they require 110 and 220. You take the front panel off the dryer, unbolt the dryer, un hook the harness that connects to the dryers control panel and slide the dryer off.
Eugene, if they'd put in an onboard heater, that would significantly help.  I've had a front loader without and one with.  I'll never have a front loader without an onboard heater again.  I keep my water heater at 120.  I'd rather have the washer heat the water than my electric water heater.  That's the only reason I didn't consider a Speed Queen in 2011.
Get the SQ front loader
When my Newton Iowa Dependable Care Maytag died, I too thought: I need a daily driver washer now, I'll fix the Maytag later. I bought the SQ TL first. After the very first load, I knew I would never use the Maytag again. Noticeably better cleaning and rinsing, larger capacity. And the electronic controls were so convenient.
Then I became aware that my wastewater often backs up in the basements of people downhill from me, and I started feeling guilty about all the water I was using. So I bought the SQ FL too, figuring I could easily resell it if I didn't like it. I rarely use the TL now.
The FL has a slightly bigger capacity. It's simply unbelievable how little water and detergent it uses (1 Tablespoon is usually plenty with a water softener), and I think it gets clothes cleaner -- especially dress shirts and sheets/pillowcases.
It has a soak cycle and a pre wash cycle. You can select both together. If you select second and third rinse you can get a total of 5 rinses. It's great.
Just a few tweaks. Jeans don't seem to get clean unless I turn them inside out but that'd be true of any front loader due to reduced water levels. And due to the lack of a heater and steam, to get a truly hot or warm wash I first run the laundry tub faucet until the hot water arrives before starting the washer, just like you do with your dishwasher. Also, in the Winter I will use a pre-wash because the cold clothes and wash tubs cool down the first hot fill. It's not a big deal. These tweaks are quick; whereas a heater or steam option would add at least a half hour of time to the cycle.
Bottom line: I love my SQ FL. Cleanest clothes I've ever had.
Since I cant pick the dryer off the washer by myself jkbff, I will get the side by side's.
I'm looking at Model # AFNE9BSP113TW01 washer.
And Model # ADGE9BGS113TW01 gas drier..
Any objections, or comments?
Thanks everyone!
How much tide HE in speed queen front loader?
I just received my AFNE9tBSP FL washer and I'm on my second load.
My question is about the amount of Tide HE per load. The installer said to use one table spoon. But the instructions say to add to the fill line of the dispenser..
That's a huge difference, because when I tried to fill tide to the fill line the detergent just drains into the washer. Meaning the dispenser must not contain or hold the detergent and if you fill slowly, you would never fill high enough to reach the fill line. I imagine you could over fill easily.
The second load I used the measuring cup from the top of the tide jug and never reached the fill line because again.. It doesn't fill up, but dump right in..
Whats the correct amount for a regular load?
Thanks
Measuring Cap
I would start with the minimum level in the cap and fine tune from there. You may need less or more depending on load size, soil, and water hardness.
Malcolm
Only use dry detergent in a front load speed queen!
I talked with the Appliance Barn where I bought them and they said SQ factory rep said NOT the use liquid detergent.. They said liquid detergent will leave a residue that will make my front load stink.. Also, I should use only between a tea spoon and table spoon of dry powder detergent.
Great.. Iv done half a dozen loads with a entire cap full of liquid and now better somehow clean that residue out with maybe dry tide and vinegar? Or just a few empty loads with vinegar?
What ratio vinegar to water is a good cleaner? I used to add 1/4 cup vinegar to each load to prevent my Maytag from stinking.
Thanks!
No worries
Don't panic.
Yes, liquid detergent can leave a residue if used in to big or small quantities, but that is the same with every detergent and softner.
Yes, powder would be my choice, but liquid will work just as well as long as used correctly.
Just go ahead and use what you like from now on.
My motto with that: Manufactueres of detergent know detergent, and mechanics know the machine, not vise versa.
Follow detergent manufactueres advice with a hint of common sense (if you notice the laundry dosen't smell fresh and clean, use more detergents, warmer water or extra rinses; if you notice detergent residue, to much suds or such, reduce dose or add rinses; if your load is big and soiled, used more, if its small and less soiled, use less).
Liquid Detergent
Is perfectly fine for your machine. Here is the detergent information from the owner's manual.
The detergent compartments are located on the right side of the
dispenser drawer. The front compartment is for detergent used in
the main wash. Refer to compartment 1 of illustration. If a prewash
is selected, liquid wash detergent added to the main wash compartment
may run into the load during the prewash. To avoid this,
use powdered detergent in the main wash compartment when selecting
a prewash. The rear compartment can be filled with detergent
for the pre-wash if one is selected on the control panel. Refer
to compartment 4 of the illustration.
Use low sudsing, high efficiency (HE) powdered or liquid detergents
that are recommended for use with frontload washers. Powdered
bleach can also be used in the dispenser along with the detergent.
These
look and sound like excellent machines. When we need a new washer, and or dryer, we will borrow a truck or rent one for a day and drive 2.5 hours or so to Lorain (Cleveland) to buy them from Eugene.
Every customer review on Google is 4 and 5 stars, so will be worth the drive, and he is deserving of the business.
Have a prosperous winter holiday season, and new year!
