merccougbird
I was hoping some members could provide me with recommendations as to what type of Turbine Oil I should use, when it comes to the replacement of the spin tube bearings and seals ? I was sold a squeeze bottle of SUPCO oil ( labelled as "Turbine" oil ) - and I found on the internet it is available at a lot of locations ( Home Depot for example ). It has a viscosity of 92 - 98.
Also is it necessary to lubricate the agitator shaft ( inside the spin tube ) ? There is only the top seal, and I would think a lot of oil would just seep down the shaft and get onto the friction material in the basket brake mechanism, causing it to slip.
Thoughts on these two lubrication issues ? Thanks !!
