Turqoise Maytag DG702 Dryer + TA702
John:
"WP built AWs had infinite water level controls not a restrictive 3 or 4 push buttons"
John:
All I can say here is that I have never felt restricted or deprived in any way while using a Maytag machine. My A806 has a enormous amount of real flexibility, while leaving off features that are sometimes more for the sake of merchandising than actual consumer need (Vari-Flex, anyone? And yes, I've owned a Lady K with the feature).
Let's just figure that everyone likes wot they likes and enjoy the dialogue!
ROTFLMAO . membership should triple- the humor is over the top.
My humble set of Maytags have been a huge joy to own, compared to the GE FL's we purchased new 7-8 years ago. Just sayin' - so efficient, fast and clothes get cleaner, with no attention to the mold/smell issue. Every machine has its own set of beauty of features- dd or bd aside. I better not say anything else - I stay awake thinking about enough already...like what other feature-ladened machines I'd enjoy owning, and they might not include the tol Maytags.
Do the Europeans conduct washer/dryer wars, too? I better really stop here.
Yes Whirlpool/Kenmore always had metered fill, and also was the only manufacturer to have a perforated tub from the very first of their automatic washers. Maybe Blackstone did too??? If you watch the "sand test" commercial for Westinghouse tumbler washers, you'll notice all those top loaders were solid tub machines.If there were a Whirlpool/Kenmore washer in the mix, the outcome would have been different. Subtle for sure, but definetly slanted toward Westinghouse.
Maytag's spin/drain was a hold over from that awful AMP design that held sand between the inner and outer tubs. They were more right than they knew when they used the ad copy, "one tub for the clothes, one tub for the dirt" except that the sand commuted between the tubs. I remember when neighbors came home from a local beach and the mother ran the bathing suits through repeated warm rinses in the AMP and finally just hung them outside to dry to finally be able to get rid of the sand. She could have rinsed them in the tub and done better with sand disposal. Just like GE and others, when Maytag switched to a true perforated tub, they stayed with the original way of draining even though they did not need to throw water over a tub wall.
Blackstone actually had a solid tub that drained from the bottom when the transmission lifted the agitator during the neutral drain then spun the remaining water in the load over the top of the tub. That's why the tub wall had those criss-cross channels.
Whirlpool had to use the spray rinses to flush off the crap that settled onto the top of the load as the machine sat and drained.
If you have ever watched closely while a machine is spin draining, what is on top of the water quickly falls into the area near the agitator. That is why Speed Queen used a long floatation rinse at the end of the wash to get rid of that stuff. Frigidaire's overflow rinse at the end of the wash was not long enough to get rid of suds and the powerful currents of water coming up the tub walls during agitation actually held the suds on top of the water. With the advent of detergents so that the problem of soap curd was solved, the draining while tumbling of front loaders remains the best way to keep dirt off the laundered items and the heavier than water soil does tend to settle into the outer tub during tumbling.
For many years Maytag did not offer a wash 'n wear cycle with cooldown except on the push button TOL model and while they were early to offer two speed machines, you could not independently set wash and spin speeds until the 806 while other brands offered more flexibility much earlier and further down in the lineup. CU commented in the late 70s or early 80s that while many machines in the group they tested offered infinite water levels, Maytag stuck with set levels. Maytag did finally improve the agitation with the Power Fin agitator, but they were late to increase the machine's capacity and then not by much. The HOH dryers were small capacity dinosaurs into the 70s. All of the refusal to innovate finally caught up with Maytag. I'm not saying they were terrible machines, but for their storied dependability, customers did not get any state of the art features while they were state of the art. As an old service man told John and me, "A Maytag will never do anything to hurt or strain itself." They would wash for those families with stairstep children shown in their ads for lots of years and Maytag was a high-priced brand that many aspired to, but nothing is perfection down here, not even the W1926 and W1986 Mieles, but they come very close.
The Strength of Maytag....
In my opinion, was that while they sometimes didn't offer as many features as some other brands, the features they did offer were backed up by elegantly simple, highly robust engineering. Owners were not burdened with lots of repairs on "gizmo" features.
There is no comparison between the bleach and softener dispensers on a Maytag and those on an upper-series Kenmore. Maytag used the simplest possible means to get the job done; Kenmore depended on solenoids and plumbing. Guess which system became the industry standard on top-loaders? It wasn't the one with the solenoids.
That "small capacity dinosaur" of a dryer had a porcelain-finished drum long after competing makes went to paint. Maytag always gave you porcelain tops on their machines long after other makes started painting those too.
And if Maytag didn't offer so much glitz at the top of the line, it offered some very solid value at the lower end. My first Maytag was an A208, one model off the BOL. My current machine is an A806, absolutely the TOL. The A208 had every feature the A806 has, with the sole exception of a console light. Even the A806's Delicate cycle had an ingenious counterpart in the 206's Fabric-Matic cycle, which did a damn nice job on some very delicate stuff while I owned it, including my late partner's surgical compression stockings, which are very easy to damage.
And Maytags wash well in my experience - my A208 replaced an upper-MOL Whirly Design 2000 direct-drive machine. The difference in cleanliness after one wash was astounding, and it improved with subsequent washes. Anyone who says a 'Tag won't wash might want to try a different detergent or something....
If you don't like Maytags, you don't like them and there's nothing I can do to change that. But please don't try to make them sound like something Granny Clampett invented herself and had Jethro build in a shed out back of the cee-ment pond.
