Turquiose 30" Frigidaire
Beautiful TOL Frigidaire Range
But unfortunately with the Tender-Matic oven control system you will be very lucky if the oven works and if it is not working or stops working good luck fixing it.
When parts were readily available for appliances this age we used to install an oven thromostat from a range without the TM system to fix these ovens, now your best hope is to get a used thromostat to try to save this beautiful range.
John
I think this is the oven control with the motor to turn the dial to lower the heat during the Tendermatic process. Why isn't this a Custom Imperial? What more could it have? $400 is too much to pay someone who did not keep the Heat Minder sensor clean.
