Tv lamp socket
From this single image, it's hard to tell exactly how the switch and lamp socket are conjoined (if at all) and if the socket is [commonly] attached to the porcelain fixture along with the switch through that single hole thru the use of a custom mount attaching to the base of the socket using standard ⅛" pipe thread, or not.
If the original lamp utilized a "custom" combination lamp socket/switch, you may need to custom-make a bracket to secure a [modern day] lamp socket that then is secured to the fixture using the mounting shaft of a new switch, thus securing the entire assembly to the fixture. Good luck.
Derek,  here are some pictures I took of a dusty old panther lamp that may help.  I think the way the socket attaches fits Steve's description above.  Ultimately, you may have to take your lamp to a lighting shop since the fittings seem to be specialized.  They may just sell you the parts for a DIY job, or give you an estimate for installing a new socket.  I hope this helps, even though as usual, all pictures were turned upside down in the posting process.
Much appreciated all of the help in the repair of the TV lamp. I will be giving this back to my mother since it belonged to her parents. I used a regular socket and used a threaded piece and some washers and nuts and it tightened enough to the body and I used a cord that has a switch too so it will stay together nicely.
@rp2813 your pics were exactly what I needed and I immediately went to the store.
Derek
An interesting TV “bias” lamp. These are still used today even with flatscreen TV;s . You can get LED strips from Philips you fasten to the back of the flatscreen set. And you could use a LED screw base bulb in your “panther light” . Do you remember the Sylvania “Halolight” TVs that had flouresecent bulbs surrounding the pix tube screen. The bias lights keep your pupils from opening too far making the screen too bright.
