UK classic Appliances March 2016
And now for something completely different ....
A long lost piece of office technology - what is it?
A comptometer.
I should say that when I entered the world of commerce in 1977 even then these machines were on the way out and it was only from older colleagues I learned how to use these - there was a very specific art to it and the operators received specific training using 10 fingers almost simultaneously. In larger companies there would have been rooms of these machines (rather like a typing pool) doing additions all the day long. This art largely disappeared in the 1960s and 1970s as computers (mainframes not PCs) became more affordable.
I never heard of this brand before, I was more familiar with the Sumlock models and in my first job they had an electronic Burroughs model
More information on this link:
https://en.wikipedia.org/wiki/Comptometer
and on their operation
http://www.vintagecalculators.com/html/operating_a_comptometer.html
http://www.ebay.co.uk/itm/111946931631?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Pinstripe Neff Oven
I knew I had forgotten something.
Back up the thread there was a query raised about the third knob on the Neff Pinstripe oven. The left knob was for the temperature of the main (fan) oven.
The centre knob for the lower conventional oven and grill (broiler).
At the time I was not sure about the left knob which I thought was to select the type of heat in the smaller oven. This proved to be the case and was largely as I stated above - choosing top only, bottom only heat and broiler. In the "off" position you get both top and bottom heat in the lower oven.
Older versions of this oven have a 4th knob - I think this may have been for a self cleaning version of this oven
vacbear,
I see the intergrated dishwasher in the white Poggenphol kitchen.
I think I may have seen a Tri-City cooker in this music video on Youtube.
"The Verve" Bittersweet Symphony.
Comptometers
Al
That's taken me back, when I started in the Cashiers Department at GEC in 1985 they were still using 'comps'. Mine was a Sumlock 993s electric model and I loved it and was still using it up to about 2005 when it unfortunately seized, by this time it was the last one in the company. So much quicker than using a calculator especially if you only used the digits 1 to 4 and multiples of for the higher numbers.
Ian
Sumlock
Ian
One of these then :)
I never used one of these myself having been "raised" on more conventional adding machines (and I have a good turn of speed as long as I don't think about the numbers or look at the keys) but was shown their operation by members of staff who used to use them - these were in the bakeries I worked in from 1981 to 1989.
In the first bakery there were a couple of them, they were on small trolleys almost the exact size of the machine which could be pulled over beside the desk when needed. In the second bakery there was just the one which was only very seldom used.
In both bakeries these (and quite a few more) machines where used to do the tabulations for the daily baking requirements although they had been replaced in the mid 1970s by computers - (both ICL 2903) which, although hugely expensive at the time, resulted in considerable cost savings in terms of staff and improved information flow - we are not talking PCs here but machines that filled entire air-conditioned rooms, although a modern PC would have for more processing power than they did. It is not widely known that a bakery chain (J Lyons, as in Lyons Corner Houses and "nippies") was one of the major pioneers in the application of computerised information systems in the immediate post WW2 period.
A word about the "doubling up" you mention. From the picture above one can see that each register (units, 10s, 100s, 1000s etc) goes from 1 - 9. However, as a time saving technique it was possible for the hand never to go above 5 - if one wanted to enter the number 7 for example rather than move physically move the hand up to the number 7 the same result could be achieved by pressing the numbers 4 and 3 sequentially, for 8 it would be 4 and again 4 - this technique could be applied was across all the registers - although it might sound complicated, it proved to be second nature to those trained in its use.
I once saw a small "portable" comp. (these were by no means light weight) which only had keys for each register from 1 - 5 - it was only when doubling up was explained to me that I understood how this worked.
I am the first to acknowledge the power and cost effectiveness of modern PC accounting based systems but I do feel some sadness as the passing of some earlier technologies and the skilled people who used them.
Al
Al
That's the one, I must admit that I was pretty quick with it, as you say so long as you don't look at the numbers or think about it you can get some speed up. I always found using only the digits one to four and trebling three for nine was much easier on the wrist ;-). We could have done with a trolley, the comps took up quite a bit of space on your desk.
It sounds like you were more advanced than we were at GEC, we were still punching payroll data on terminals well into the 2000s!
Ian.
