Got to agree regarding the Fairy Active Bursts having Fairy rinse aid sold with them! hehe
That does not quite make sense, but then no combination tablet really makes sense to me because one almost always needs separate salt and rinse aid anyway, even in soft water areas!
Quite simply, all dishwashers need to have separate salt in them, and that also applies if the water softener in the machine is set to minimum – that is, for a soft water area. In this case, only a small amount of salt will be used. However, as always, it’s important to check with one’s local water supplier to see what the *actual* water hardness is at each address – it can vary!
We’ve done this in our area and set the new Miele dishwasher appropriately.
Just look at a water bill, go to your supplier’s website and see if you can find any link that mentions water hardness, fluoride levels quality, etc.
The link shows an example for my area, though they’ve misspelt my town’s name – grrrrrr! LOL
Crumbs – if it’s not “Bishop Stortford”, the apostrophe gets left out! LOL
It’s “Bishop’s Stortford”!!!
Anyway, where was I? hehe
We always use salt and rinse aid, although some combination detergents may require a slight reduction in the amount of separate rinse aid added to the final rinse. However, this is not always the case, which begs the question: “Is there actually any rinse aid in some combination detergents?!” LOL
We’ve had to change a lot of products in this house over the years due to my sensitivity to chemicals and perfume, and I’m afraid we’ve had to do the same with laundry and dishwasher detergents, so I can’t use Finish, even though the perfume used is limonene (basically made from citrus fruits with a bit of chemistry involved). All of the stuff we use now is perfume-free because it simply has to be.
A shame because Finish Classic – we would use all-Finish products in our machines – are the best in our experience, though it can of course vary depending on one’s load (the type of dishes and the types of food) and dishwasher.
Also, *sniff* no more Persil.
*cries eyes out uncontrollably*
Still, I still have my Mieles! hehe
Oh, and my Miele dishwasher is sooooooooo quiet – it’s amazing!
I’m hyper-sensitive to sound, and even I don’t realise it’s on at times – a real godsend!
Which? tested dishwashers a little while back, and this one came back as the quietest slimline on test.
However, I do quite miss the AEG we had, which was nice, but rattled terribly – most likely a sort-of DOA/‘Friday afternoon’ one.
Carl
