under counter commercial dishwasher - $1900 (tallahassee, FL)
stricklybojack
Feb 24, 2014
1,811
South Hams Devon UK
Ad copy:
Fagor Under Counter Dish Washer, Model# FI-48W for sale : the purchase price was $3500, its 1 year old , use it about 10 time, will sacrifice $1900 or best offer.
Heavy duty stainless steel construction.
Auto-fill.
Built-in detergent pump.
Built-in drain pump.
Automatic drain valve to prevent overflow.
Built-in electric booster heater.
Utilizes fresh hot water rinse.
Electric tank heater.
Low water heat protection.
Hi-limit thermostat.
Built-in rinse aid dispenser.
Standard 20 x 20" racks.
Door safety switch.
Built-in hot water assurance.
Fully automatic wash and rinse cycle with correct temperature indicators for consistent cleaning.
Removable front electrical panel for easy access to controls.
Vacuum breaker.
Stainless steel non-clogging individual wash and rinse arms.
Wash tank with filter and tray system.
Adjustable legs.
Electrical cords, drain hose, and fill hose supplied for quick and easy installation.
Standard with: CT-10 all purpose rack, CP-16/18 peg rack, Cutlery containers.
Capacities Heating
Racks per hour 30 Electric wash tank heater 2.8 kw
Dishes per hour 750 Electric booser heater 2.8 kw
Glasses / cups per hour 1080
Wash Tank 6.6 gal. / 24.9 liter Operating Cycles
Wash time (seconds) 2 setting (100, 160)
Water Consumption / Requirements Dwell (seconds) 5
Gallons per hr. (Max use) 27 gal / 102 liter Rinse time (seconds) 15
Gallons per cycles .9 gal / 3.40 liter Total Time (seconds) 2 setting (120, 180)
Inlet temperature (Optimum) 140°F / 160°C
Flow rinse pressure 15-25 PSI
Wash Pump Motor
Motor (hp) 1 hp
Max. clearance for dishes / glasses 12-1/2" / 318 mm
Temperatures Shipping weight 160 lbs / 73kg
Wash 150°F / 66°C Shipping volume (cu.ft.) 15
Rinse 190°F / 88°C
