My beloved Unimac seems to have an issue… It has developed a rattling noise of some kind while coasting down from spin. I’ve had the top panel, toe panel, and rear panel off and cannot seem to find anything loose that could be making the noise.
There is a little bit of play in the main pulley on the drum (not wobble, just a touch of rotational play) that could be causing it, but there also seems to be an issue with the main bearings I fear as the center of the back of the drum gets pretty hot but the end of a cycle. (Hot enough that I don’t want to keep my hand on it but I can.)
Hoping someone here might be able to help me diagnose the issue as I’ve never worked on a commercial machine but I guess there’s no time like the present to start learning!
As for the pulley, I can understand play developing if there is excess friction in the bearings, but I don’t know how much play, if any, is acceptable. I also don’t know if it’s common for heavy duty bearings like these to heat up some amount during use.
According to the machine’s log, it has run just 285 cycles in its lifetime, so there is definitely something not right, it’s far too young to be having such issues.
Video of intermediate spin
