Uninformed Washer Users
"Which one Is worse? Washing everything on cold or washing everything in hot?"
Different answers on this one. After installing a temper valve about 12 years ago, I'd say anyone washing material requiring cold temps under 85F should walk the plank.
I have my water heater set at 162F so washing anything but 100% white material designed for hot water is guaranteed to lose some color and possibly shrink.
You’re welcome to call me crazy
But with me and he says I pre-treat everything I wash in warm to hot water together as my laundry wouldn’t really have enough Articles of clothing for colours or whites as separate loads, so essentially I wash everything in one load after protruding the stains checking the pockets etc, I have not had any adverse affects yet although I do not wash my clothing in anything 55°C or higher, drying is a different story just crank up the temperature and let it run its kind of what I do, My mum only has cold water hooked up to her machine and it does not have a heater so she’s only washing in cold water and the water can get down to about 10°C or so, I’ve constantly offered to hook up hot water to her machine yet she says she is fine which is a downright lie
I’ve heard of people stuffing their washer with so many clothes to the point where you couldn’t stuff any more clothes in and that’s definitely overloading. I usually tend to ever so slightly under load my machines and since I am in charge of the machines I have around my house overloading won’t ever happen.
I am sure people have overloaded dryers before and that will simply cause the clothes to not dry or have ridiculously long dry times along with wrinkled laundry as well.
My wife over stuffs the washer and dryer constantly, even after i've explained why she should not be doing that. So many times ive come to do a load and found them so packed that nothing could move.
She also pours crystal softner directly into the front loader on the clothes before starting. Maybe thats how you use the crystals. IDK I typically use liquid in the dispenser.
(not picking on her lol)
My advice to stupid washers is
to use the machines correctly, or don't use them at all and let us washer fans do it properly, especially for high-tech front load washers. I could quickly figure out how to use most high-tech machines. Same for mechanically controlled ones. They don't even want to watch through the windows to make sure everything's cleaning properly with everything separated to the tee!
I'm a toploader fan myself but I'd never put one in a laundromat anymore. Very few know how to properly use one this day and age and overloading takes a toll on the machine. There's little to no harm done by overloading a commercial front loader.
honestly....WHO CARES?
if I see someone overstuffing a machine, using the wrong temp/cycle/selection....what do I care?
as long as its not one of my personal machines.....who gives a rats ass, and why is it any of your business?....
its NOT your machine, NOT your clothing, NOT your money....
I am sure you probably do stuff improper that annoys the hell out of others....do you learn?.....
the only time I would recommend an opinion, is if its Singles night at the Laundromat....and a handsome guy needs help while his clothes are washing!
I know this will make some cringe!!
<span style="font-family: helvetica;">Until I joined this group, I never would have known there was a proper way to load a washing machine.  I think I was smart enough not to overload as was seen in some of these pictures, but I wouldn't have known I needed to worry about anything more than good sorting, the correct cycle and what I thought was the correct amount of detergent.  I suspect I am not alone.</span>
<span style="font-family: helvetica;">But I have to agree, if it's not my machine(s) I really couldn't care less.</span>
#51
Your comment got me to thinking... How DID I learn how to do laundry properly? Again, I think a good chunk of the credit goes to my grandmother who would what she was doing, why she was doing it, and how she came to that conclusion when she was doing laundry. Sorting, cycle, detergent, bleach or not, what size load, what temp for the water, etc. So when I started doing my own laundry I just did what she did simply because I didn't know anything different. Later, when I got to college I was surprised that a lot of people in my dorm had no idea how to wash their own clothes.
Other people? I don't really care unless it effects me or I am asked.
One funny thing did happen once. I was working for an office cleaning company at the time. I'd just loaded mopheads and cleaning rags into a heavy duty machine and added the appropriate (read: OBSCENE) amounts of bleach and detergent and set the cycles for the hottest & longest. Damn! The change machine was broken. I went across the street, got change, and came back 2 min later to find the mopheads, etc piled on a table near the door. Some random guy had taken the stuff out, put his own clothes in, and started the cycle. He was staring me with this expression that dared me to say something. I looked at his load tumbling in the machine: I saw swirls of black, white, and red garments in decidedly pink-ish water. I checked the settings...... Yup, still set for the hottest and longest! I started cracking up which totally confused the guy. I decided I didn't want to be around when the cycle finished so I gathered up my stuff and headed out to another laundromat.
I always wondered what happened when he saw the results of washing colored items in a hot with a ton of bleach.......
Love that story..
<span style="font-family: helvetica;">#52 - I love that story.  I'm not sure why I take a little delight in knowing the guy got his.  I'm normally not like that, but some people are so selfish.  Yeah, I'd like to know how his clothes comes out.</span>
<span style="font-family: helvetica;">I suspect I learned from my Mom and then as I've gone through the years I've made adjustments to meet my needs.  One thing is different, is she always had a suds saver in her machine and I can remember pulling the water back in the machine.  I've never owned one, I guess I thought that was a little gross.</span>
<span style="font-family: helvetica;">I know I am a little over the edge when it comes to how I do laundry, but I just see it as one of those pleasures I have in life.  Hubby just shakes his head that I don't throw stuff in the washer until it will hold no more and then in the dryer on high.  I dry at different temperatures, hang some things, etc.  Sometimes you walk into our laundry room and have to duck to avoid the stuff hanging here and there.  LOL.  Here it is this morning as I type this with the jeans I have hang drying instead of machine drying.  Ha.  Oh well, this virus makes it worse because I need to find more of life's little pressures in the house vs. the mall.</span>
I learned to sort from my mom. I was always diligent about separating whites from lights from darks and then washing sheets in one load, towels in a separate load, and bathroom rugs separately as well.
After watching this video, I tried this sorting method and it has worked out nicely. I wouldn’t consider her an expert on laundry in general, but I do like how she sorts by textures - washing the heavier items in one load and the lighter items in another. I have a load of dress pants and sweat pants in the Miele now with a mixed load of my dress shirts, colored t-shirts, socks and colored underwear in the LG. I also have two pullover sweaters washing separately in the sidekick. Towels will be washed in a separate load, my sheets will be washed separately, and the blanket from my bed will be washed in another load with a throw blanket from the couch. And then of course my weekly whites. Turns out I do quite a few loads for a one-person household!
I’ve learned that most of what I would consider “darks” and “lights” are colorfast, so they can be washed together in warm water without issue. If I have new dark items I wash those separately for a while, but modern fabrics don’t seem to bleed as much.
Old habits die hard and this was a bit of a change for me, but I like it so far.
https://www.youtube.com/results?search_query=jordan+page+laundry
The way I see it, is this.
If something happens to stupid consumers who do what has been stated in these posts, oh well. They have been warned hundreds and thousands of times. YouTube user sharkie626, I and others have warned them through video or comments sections. If you abuse the machine or cram it to the brim, you get what you deserve!
It's amazing how people can screw something simple up. They can be too lazy to do it properly as another user said on here. I'd rather do it properly and take my time.
Macomb county has
some idiotic people. At least they don't represent the states majority. I see how they drive, act in stores, and treat others. Making right turns from the left center lane when there are no turn arrows, total disrespect for speed limits too.
If I drove that way I'd be caught and ticketed. Some also remove face masks after entering a store with a sign at the entrance requiring them.
My brother in law is one of them. He owns a UPS store, and refuses to mask up. He won't allow my niece to work with one, anywhwere. So he pays for her cars, gas, insurance, etc. He thinks they trap the virus and you catch it that way. Um, does logic then say that it is also trapped from getting in from the outside of it? Wash, or replace often. My sister is at odds. They were in marriage counseling all summer. It was pointless. He is a huge conspiracy theorist and follower. Thinks it's just a nornmal flu.
Sure live free, or die, but he has no right to spread it. Most who do have zero symptoms.
Since you're going totally off topic anyway, I have the same stance on the face diapers as your brother in law! They are the most useless pieces of garbage that ever existed, and yes, I firmly believe the masks are part of the problem- trapping viruses and bacteria and releasing them. There is no evidence that wearing a cloth mask over your face does anything but show compliance- if it was so, covid numbers would be down to the point of non existence. Neither I nor my mother have worn a mask since March, and neither of us have been healthier. I have been exposed to covid at least twice, with no symptoms, and I know several people who have had the virus. Several FAMILIES actually. No hospitalizations, no deaths. All have described it as being a short lived bad cold. We have no plans of being vaccinated and will be having Christmas with our family, regardless of what our tyrant governor demands.
