We cannot forget the purpose-built gear drive logging locomo
<!--[if gte mso 9]><xml> <o
ocumentProperties> <o:Template>Normal</o:Template> <o:Revision>0</o:Revision> <o:TotalTime>0</o:TotalTime> <o
ages>1</o
ages> <o:Words>72</o:Words> <o:Characters>414</o:Characters> <o:Lines>3</o:Lines> <o
aragraphs>1</o
aragraphs> <o:CharactersWithSpaces>508</o:CharactersWithSpaces> <o:Version>11.1282</o:Version> </o
ocumentProperties> <o:OfficeDocumentSettings> <o:AllowPNG /> </o:OfficeDocumentSettings> </xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:Zoom>0</w:Zoom> <w
oNotShowRevisions /> <w
oNotPrintRevisions /> <w
isplayHorizontalDrawingGridEvery>0</w
isplayHorizontalDrawingGridEvery> <w
isplayVerticalDrawingGridEvery>0</w
isplayVerticalDrawingGridEvery> <w:UseMarginsForDrawingGridOrigin /> </w:WordDocument> </xml><![endif]--> <!--StartFragment-->
<span style="font-family: TimesNewRomanPSMT; font-size: medium;">
With smaller diameter drivers (29” to 36”), driveshafts and gear drive,<span style="mso-spacerun: yes;"> </span>these work horses were not fast, but could haul heavy loads up steep inclines on uneven track and sharper curves then other locomotives!</span>
<!--[if !supportEmptyParas]--> <!--[endif]--></span>
First, the most widely used of the geared Locomotives, the Shay.<span style="mso-spacerun: yes;"> </span></span>
With more than 2700 built from 1878 through 1945, the Shay had 3 vertically mounted cylinders connected to a crankshaft, turning drive shafts which drove ALL axles on the locomotive and tender, making it “all wheel drive” as it were.</span>
<!--EndFragment-->
