Any of you have a convection oven and can me advice on how to use it?
I have had a General Electric Spacemaker Convection/Microwave for several years. I have attempted to use the convection mode a few times, but usually get lousy results.
This may, in part, be due to the fact I am a lousy cook. ha But things just don't seem to come out right. I have tried to make apple crisp twice and the top burns and yet the apples are not done, when I use the time and temperatures given in the recipie. (On the second attempt, I put aluminum foil over the top after the topping started to burn. The air moving around kept blowing the foil off the baking pan so I had to finally weight it down with a fork. I eventually got the apples done with only a partially burnt topping.)
Frozen pizzas also see to burn on the top, by the time the crust is done. I keep the rack down on the lowest level.
I am curious about others experiences with a convection oven. Is one supposed to reduce time or temperature (or both) when using a convection? Is so, how much??
