Have uploaded this latest video showing The Zug Adora performing the STEAM cycle. The water is heated by the main element in the base of the drum, this ensures a steady stream of steam throughout the drum allowing the clothes to be completely bathed in the steam continuously..You will here the injectors pumping small amounts of water into the drum to keep the minimum of water over the heater at all times allowing maximum steam output with minimum usage of water. You can also hear the hissing of the water when the heater kicks in...
Having used Steam Programmes on washers with Steam Injector units (like a seperate kettle with a pump jet, i think this method is better as it allows the drum to be completely full of steam for maximum benefit.
<iframe width="640" height="360" src="" frameborder="0" allowfullscreen></iframe>
