vaccum cleaner question
Sled?
All north American Electrolux and Aerus vac's since the early 1960's have had wheels. The last one with gliders was the LXI of the late 50's. Miele hasn't made one since then either.
European E-Lux's and Miele went to plastic tanks first. Electrolux in Canada and the states about 1979-80 after thre Marquis was discontinued. Those were still sold under a generic brand last time I looked on Vacuums direct, or E-vacuum stores.
When AB Electrolux (Sweden) who owns Frigidaire decided in the 90's to market upscale major appliances as Electrolux, they divested from the north American concern, and the name changed to Aerus. The Guardian, and possibly the Classic (Pre-hepa filter Renaissance), is still made. I'm sure they sell in Canada if so.
Just search online. Hope that helped Pierre.
Pierre,
your welcome, and what is wrong with your CV system? Often the motor brushes can be replaced, or the motor if the seal between the mounting and the tank is still good (not dry rotted). An Amitek Lamb 2 stage bypass 120 volt motor is not costly. My Hoover CV is from 1996, and still going. I replaced the hose about 10 years ago with one from Canavac. I like that it has no bag, just a polyester filter to brush clean when emptying the tank.
A new power unit can be bought for about $500.00 from Canavac (Canadian), Beam, etc. They are universal. The bypass 2 ir 3 stage moors are better. You can tell them apart by the metal exhaust horn they have vs. a plastic one. The least expensive motors are flow through, and don't last as long.
A new quality cansiter vac will set you back about $700.00 to $1,000.00. An Aerus even more. The refurbished generic Epic models I haven't priced lately, but they cost a lot less. They only have wooden beater bars. A Miele with a good powerbrush runs about $800.00 to $1,200. The top of the line $1,400.00 They are great, and super quiet, but bags and hepa filters costly.
Others avaialble are Riccar, and Simplicity.
I also have my moms Eureka Brandywine powerteam canister from 1980. Still going strong, but no hepa filtration of course. I use the powernozzle on the central vac often. The Vibra-groomer is still among the best ever made.
pics of central vaccum
here are pics of the central vaccum plus i have to start it manuel the control on the handle no longer function, so the big question is should i suggest to my mom to consider replacing it if yes what would be the best brand for central vaccums there are no longer sears stores where i live i think it replace a beam central vaccum that was in place since 1983 was replace around 1996 or 1997 do not remeber the excat year
If the power unit still turns on and it works fine, then I would first focus on fixing the hose and unclogging it if you're on a budget. Here's a video from a friend of mine who explains how to easily troubleshoot a central vacuum.
And here's another video explaining how to easily unclog your system.
If you're looking into upgrading just the kit by itself, here's what I would recommend. In my opinion the best overall kit would be the Stealth from MD Manufacturing. For better deep cleaning, I would go for the Wessel Werk EBK360 kit.
If you're looking into upgrading just the power unit by itself, I would highly recommend to look at the power units from MD Manufacturing. Or if you like to buy stuff that are made in Canada, then I would highly recommend to look into Cyclovac.
https://builtinvacuum.com/
http://www.cyclovac.ca/
Pierre,
if it works after cleaning, etc. you can upgrade the hose to one with a 6 foot pigtail for a power brush that plugs into the nearest wall outles to it. Hoses are available with the 24 volt switch on the handle as well as for the power nozzle. Mine only has one for the nozzle. The unit starts upon connecting the hose to the inlet valve. The 24 volt combo switch allows powering off the main unit from other rooms.
We had a Nutone central vac for years that was garbage, I think they installed with the Nutone Food Center. The vacuum had two power heads one was like a huge ugly cinder block , I think it ran off of suction and the other was electric and that horrible imitation wood crap. They didn't work well the hose connections and power on sucked bad. My Parents bypassed all that and just put a switch next to the machine in the garage . Mom ditched that system and got a Drain Vac/ PureVac its a nice and powerful machine you can even vacuum up water and what not. You never have to empty it , the machine uses water and a drain. Kinda like a Rainbow Vac.
I emptied mine yesterday
since winter began. The poyester filter has a hole in it from glass, or a sharp nail. It's working fine, but I'm not going to replace it. The unit is from 1996 and has paid for itself in bag savings. My luck if I do it will need motor brushes or a motor next. It's a 120 volt 10.5 amp 2 stage. 110 inches of water lift. I put a muffler on it, but I'd upgrade to a Beam Serenity series, or Canavac equivalent.
If a filter has a hole-leak in it-replace the filter.Your vacuums motor will thank you.Dust leakage is BAD for vacuum motors!It can clog the motors fans-throwing the fans off balance-killing the motor-and the dust can get into the bearings.
Greg, Rex,
I'd replace the filter but I don't know how much longer the main motor seal is going to last. I paid $400 for it in 1996.
Greg, our place is under 1,500 sq. ft. We had a dog that I was very allergic to the dander, so thats why I got it. It's in the garage, and the only inlet valve is in adjoining wall. A 35' hose reaches every corner of the house both ceilings (with a wand) and floor. I can clean the basement stairs too. The smallest units are designed for condo's and motor homes.
Mike
I would also replace the filter. Otherwise you would have a greater chance of your motor to go bad. Out of curiosity, what model is your Hoover? I'm not entirely sure if there is actually a replacement filter for it anymore or not. At least there are non available from MD Manufacturing's website. I'd assume that you still could, for over 25 years they had been made by Cana-Vac. But definitely for sure you can get a new motor seal for it, they're very inexpensive to replace. However if you're ready into upgrading your Hoover, here's what I would recommend. If you really like your Hoover, then I would suggest to into Allegro. Cana-Vacs are good to but non of them have a built-in utility valve like Allegro. Some Beam units are ok but some not so much. But if you want the best overall bagless central vacuum unit for your home, then I would suggest to look into Vacuflo's true cyclonic units. They don't use a bag or a filter, you can see what's coming into the bin, and all of the dust would be blown outdoors. The only downfalls with them is like Cana-Vac, none of them have a built-in utility valve. They are required to be vented outdoors. And they're not cheap, but basically at the end of the day you get what you pay for.
Thank's Alex!
I looked for one. I think one for an MD might work, or any with a clamp mount and sand bag weight. About $50. It's had that hole for a long time. It has a bit of bearing whine on the wind down now. I'm surprized it hasn't needed yet needed motor brushes too. It was made in Canton, Ohio. It's maroon color.
We have no pets now, and it's just us two, so I run it about once a week. We only have area carpets and wood floors, so I use a dust mop for quick tidying up.
Hmm
I'm actually now curious to see pictures of your unit if you don't mind sharing on here:) As far as I'm aware of, there were two units that Hoover made by themselves in the US. The 400 and the 550, they were both cyclonic models. Then the rest with it's inverted self-cleaning bag were made in Canada by Cana-Vac from my understanding. If your Hoover with it's inverted self-cleaning bag was also made in the US, this is definitely new to me:)
