Vintage Caloric Dishwasher w Mint Interior - $70 (Manchaca and Stassney
Yet another machine that was "too inefficient" be used daily, or without company, I suppose.
At from what I can gather from threads on this site - all the more horror for the unfortunate person who comes across it and buys it!
This is the Potscrubber 3 - So that should mean PermaTuf tubs.
Although, I've heard these machines love to leak from the drain-valve, trip-shaft seal. Apparently that inefficient motor helps keep everything dry, and not so rusty!
Not too bad
This is a Potscrubber III model, and they had Perma-tuff tubs and heavier duty nylon racks, so the usual rusting was all up eliminated. These models also cleaned well because they had a self cleaning filtration system, which permitted GE to lower the amount of water used in its normal cycle.
That said, it still used copious amounts of water, had a very inefficient pump, and limited loading versatility (although the top rack holds a lot). Models below this still had the plastisol lined tanks, and are should be avoided for daily use.
This model is the entry level to the PS III line; many members here have (or had) the GSD 1200 or above (myself included) who are/were very pleased with these machines. They clean well.
Verdict, please! I might buy...
I'm in Austin. Should I buy it? I, too, have read here terrible things about caloric in general but what about this particular model? Please advise? Would you?
