Surface cooking with resistance electric elements
On a coil top electric range on the high heat setting when boiling water, etc. the element should never get red hot.
On a smooth top range flat cookware does help but it’s not as important because it’s cooking with radiant heat. The element is going to be red hot always when energized,
Hi Eddie, that tea kettle should not be used on any electric range unless it’s magnetic and you want to use it on an induction burner that would be fine. The small elements on your old GE electric range would’ve only been 1325 W.
Hi Ralph people generally like their smooth top electric ranges a lot their day is far from gone. I’m not sure about your two burner imported cooktop, but it should do fairly well. I don’t think it has a particularly powerful burner on it, however.
John.
