launderess
In doing some research on possible replacement for my dead dw have been reading comments/information about some vintage units.
If one understands correctly certain dishwashers such as the Mobile Maid heated water for one or more wash cycles, not just the main as is often found today. However given often how short these cycles are (often <ten minutes) it seems a horrible waste of energy. Why heat all that water only to send it down the drain a few minutes later? Then the next cycle begins and the show starts all over.
Understand the rationale behind multiple water changes as they are the only way to deal with bits of food in the absence of a filter and or grinder, but still...
Commercial dishwashers at least hold that hot water and use a different arm to spray rinse water.
