Thanks David! I do think the push/pull has something to do with defrosting. Your explanation seems to confirm it.
The gasket you linked to is the type I bought at my local ACE, but I had to try three sizes before I got it right. In my case, the extra large size did the trick.
The fridge seems to run an awful lot. I'm keeping an eye on it, but since plugging it in night before last, every time I've gone to check on it, it's running. My '39 Westinghouse barely ran at all. I think it's a refrigerant issue, as the evaporator frosts only about halfway up the sides, but some tubing behind it is seriously frosted over. I recall a similar situation on one of the projects you posted here, but I know the solution is too complex for me to pursue. It seems that boiling hot water in a tray laid on the evaporator helps even things out, at least temporarily.
This is why I'm running the fridge before I start anything cosmetic. It may run itself to death if I keep it in continuous service.
Meanwhile, that GE compressor is still on ebay. I've put out a request on Nextdoor for someone familiar with refrigeration who might be interested in a side job. Fixing the Combination is still the ideal scenario.
