There were two similar models, this one with the light above the control panel and another one with the light below the control panel at this time. I think the one with the light below the control panel was a little more deluxe and, in addition to the two timed dry heats, offered the economy setting. With the long timed dry cycle, this could be used on 120 volts. From examining these in the store, the gray area of the control panel looked like it was porcelain. It was a heavier finish than paint. Compared to the vertical control panels of the previous years, these sure looked ugly. I managed to get my parents to buy the model a couple of years newer with the brushed aluminum and black control panel that had the start button on the left and the timer with auto dry on the right. It also had pedal door opener and drum light. The auto dry cycle overdried everything so we only used the timed cycle, but I wanted the drum light and the pedal door opener so we had to get the auto dry cycle. As in other Clothes Conditioners the timed Dewrinkle cycle meant that the last 10 minutes of the timed cycle was the no heat fluff. My twin sheets would dry perfectly when the timer was set to 21 mintues.
