kate
Active member
A self-cleaning wall oven from the late 50's (JKP07) cannot lock. When the door is open, you can press the latch release and slide the latch handle all the way to the right. When the door is closed, the latch handle will not move. The slider-slot on the back of the door stays covered by a metal patch that can't be pressed in or moved. Does it sound fixable? Your comments will be greatly appreciated.
Kate
Kate
