I never heard of that brand name. But growing up, many of the older homes in this area had similar gas cooking and left side room heaters although mostly stinky kerosene instead of wood. Alot of families also had a seperate storage tank behind the stove with a coil that ran around the firebox and heated the domestic hot water during the winter. You obviously could not have the heater part going in the summer. The ones with the center ovens, like this one, could bake using either gas or radiant heat from the left side heater. Only problem with stoves like this is you had to have a chimney connection and they basically took up an entire kitchen wall, sticking way out into the room for the wall clearance.
