Determining age is kind of tricky on this one, but I'm leaning toward 1958. The aqua interior debuted in '58.
However, if I'm seeing things correctly in the full frontal with doors closed, it appears the fresh food section has a full-length handle. That's a '57 design treatment, at least on the top freezer models. In '58, the fresh food section handle was shorter on the top freezer models.
Maybe it looked weird to have a cut-off handle when the fresh food section was on top, considering the freezer section drawer sports a full-width handle, so perhaps on those models they went with full length. Also, the script on the compartments is the same as on the '57 and '58 models. In the advertisement for the '59, it appears to have changed to block letters and in blue instead of red.
So can the experts advise if Frost Guard was offered in 1958? I agree that it would likely be proudly badged as such if it was indeed frost-free in both sections.
Strangely, I'm sort of enjoying the defrosting procedure with my '57 top freezer model. There isn't much besides coffee beans, vodka, limoncello and "blue ice" packs in the freezer, most of which is contained in a medium sized plastic webbed basket, so tranferring into the big Monkey Wards freezer isn't a chore. I remove the drain cap, place the "Red-E-Defrost" in the freezer, plug it in and shut the door. The freezer is de-iced, defrost water drains through freezer floor and is routed with tubing into the fridge's rear trough, then down rear interior wall to fridge floor, is directed with grooves to the floor drain and drips down into the pan behind the grille. Freezer is wiped out, re-stocked, and fridge is up and running again, all within 45 minutes and with no major muss or fuss. Not bad.
