Virgin Load tonight! Washer Bling
What a beauty!
That is really a gorgeous machine, and a testament to your restoration skills! It's amazing how much detail and quality once went into control consoles. Contrast that with the ugly monochromatic touch pads that pass for control consoles on modern machines.
I'm keeping my fingers crossed for a flawless wash on the other side of that window!
Congrats on getting this one up and running Jon!
Thanks for the cool pixs. Beautiful machine!
I knew you could make work again.
Great work Jon, When Cal and I come to visit we will bring a camera and take some videos to post. Can't wait to see you and Al, and all your wonderful washers. Jeff
What a beautiful machine !!!
It has so much chrome it looks like an automobile grille from the same era.
Many happy loads.
Every machine can be conquered! :)
Jon, congratulations on finally getting the '55 back in service! What a beautiful machine, and what an accomplishment too on the mechanical work. Keep us posted on the maiden load (with the cabinet on, that is)!
Wonderful pictures Jon. I love those close-ups of the control panel. I see there is a heater section on the temperature control, what is that setting for? Does it heat the water to hotter temperature than hot? And is there a fourth setting hiding behind the dial itself? Enquiring minds want to know!
Good morning Louis
yes that dial when set to HOT in wash activates the magic heater which is a 220V heating element in the washer that "keeps the water hot through the wash cycle". So it doesn't heat it up any more than what enters the tub but maintains the heat of the water.
But this only works in the wash cycle not the soak or rinse.
Louis
I think what you are asking about is The "Magic Heater" which is the control in the center and it works like this.
It has two positions for wash water temperature. One is WARM the other is HOT. When set to HOT, hot water is filled into the machine.Then and only during wash cycle a 220V heater element buried in the tub is activated and keeps that water hot so it does not cool during the wash cycle. It isn't powerful enough to heat the water hotter than the temp it filled at but it won't let it cool down.
This heater is only activated during the wash cycle not the rinses.
Does that clarify its function for you?
jon
