Voltage Reduction
tomturbomatic
Gold Member
May 21, 2001
21,822
Beltsville, MD
We had one yesterday. For the first time in all of the years I have owned the Friedrich in the kitchen, the compressor went out on overload. The fan stayed on, but the compressor made some strangulated sound and shut off. I let it cool for a while, went outside and threw some tap water on the side of the compressor shell and on the condenser coil. She started back up when I went back inside and turned her on, poor thing. The compressor has been running flat out for weeks. I guess it deserved a rest. I ran the central system for an hour like I did the previous evening to help out then shut it off and went to bed.
CU used to test window ac units for how well they fared during the extreme conditions of high temperatures and reduced voltage. I have never noticed any problems until yesterday.
I very well understand high temperatures but why on earth reduced voltage?! Why would I want to do something like that? Especially in a test? To me it would make more sense to run the machines with a dirty condenser or evaporator and see how they cope with bad maintenance.
Lower than ideal voltage makes electric asynchronous motors run hotter by drawing much more current and produce less torque! A sure combination to burn them!
Could it be that the windings in the compressor are loosing insulation? Or you're low on refrigerant?
low voltage happens all the time in summer...
as mentioned above. In August 2003 the entire power grid went down in 5 or 6 Northeasten states due to extreme load and some mistakes in management and equipment failure. We will never forget that event!
In some parts of
the United States, the grid is at least 75 years old, if not older. 75 might not be too old for a person, but it's pretty old for a unit of infrastructure. It is amazing to me that there has not yet been a catastrophic long term failure. The blackout of a few summers ago was just a precursor.
Not to get (very) political, but I think investing in infrastructure like the grid, and water mains, and bridges would be a wonderful way to deal with unemployment.
Lawrence/Maytagbear
<span style="font-size: medium;">Almost every summer during a heat wave, our voltage gets lowered. The Friedrich and the Whirlpool shrug it off. They work flawlessly. But the Kenmore starts cycling on and off. The compressor runs for much shorter cycles resulting in a warmer bedroom. I'm coping for now, with the living room AC on, and the bedroom door open, the bedroom cools down nicely.  When the summer clearance sales start, I'll replace the Kenmore. Pity, if not for the lower voltages, it works just fine. </span>
<span style="font-size: medium;">I agree something has to be done with our power infrastructure.  I've been through 3 blackouts here (1965, 1977 and 2003). I vaguely remember the '65 blackout, but the '77 and '03 I'll never forget. I will never understand why we can't have a modern power grid. I'd gladly pay higher rates to help finance it's modernization. </span>
"Not to get (very) political, but I think investing in infrastructure like the grid, and water mains, and bridges would be a wonderful way to deal with unemployment."
Wonderful idea, but it would improve the economic situation of millions and that is not what the Republicans want under a President from the Democratic Party, so to spite him, all must suffer, just to get very political and hot like the Friedrich's compressor. It will take a Republican politician falling through a bridge to bring about infrastructure inprovement.
The elctrical situation is worsened by the splitting up of electrical generation and distribution so no one wants to make investments anymore. One company generates electricity which is fed into distribution lines owned by other companies and sold to consumers by still other companies.
The first NE Blackout
A friend was caught on the Yale & New Haven Railroad (is that the right name?) on the way back to Westport. They spent the night in the chilly dark cars. When the power came back on the train returned to NY and he went back to work. I remember the Life magazine article about the first huge blackout. It mentioned all of the things that were happening just before the lights went out and one of the things mentioned was ovens being switched on to prepare dinner.
Voltage reductions would happen frequently at my aunt's, when she lived in Brandon, MS. It would cause the refrigerator, freezer and central air units to have trouble starting.
When she got the Kohler gen-set installed, the automatic transfer switch was set to start the generator whenever the voltage dipped below 85% of the normal voltage for more than a few seconds.
Between the frequent outages and the brownouts, that generator got lots of use.
IIRC Friedrich Units When Tested Under "Brownout" Co
By CR were all over the place, some models fared better than others.
Years ago when NYC was suffering through a prolonged heat wave our old Friedrich Wallmaster (built in the 1980's) could not cope with voltage reduction conditions suffered via ConEd. The compressor kept cycling on and off and you could hear it straining. At first we thought something was wrong with the unit, but a telephone call to Friedrich's customer service in Texas told the tale. Their online tech told us he and the rest of that department had been getting tons of calls from NYC area reporting the same problem. Their advice was to shut the units off until power company restored full voltage to avoid unit damage.
Brownouts can even happen in the winter or during the holidays-when everyone has the heat on full blast-holiday lights and cooking.Have seen it at transmitter sites where you have line voltmeters in the transmitters-and transmitter blower motors struggling,too.At the plant I work at now-we have one transmitter that shuts down if the voltage goes too high.So,you have to bring up another transmitter to sub for it.The too low voltage as in brownouts can even be more dangerous as all point out--to motors!
interesting evening so far..
<span style="font-size: medium;">Consolidated Edison issued a voltage reduction alert along with a warning that if we don't shut down all "unnecessary" appliances we would loose power.  The lights are dimmer, and they keep flashing. At one point they completed went off and flashed on again. This is the worst voltage reduction I've ever seen.</span>
A friend of mine recently had a power reduction problem but it wasn't caused by the power company. It was caused by a bad ground. The ground connection at the service drop was bad. There's also a safety ground wire clamped on the cold water pipe but that one wasn't enough (or it's also bad as removing the link from the safety ground to the power company's ground in the circuit breaker panel didn't seem to worsen anything)... When using 110 volts appliances such as window A/C units, the sump pumps in the basement or the fridge (which happened to be all on the same side of the circuit), power would drop to 106 volts on half on the house's circuit while it would rise to 131 volts on the other half, causing most lights to dim but others to go very bright! The fans on the A/C units were also turning very slowly when it suddenly happened while the one in the bathroom would increase it's speed as the remaining power from the lights and other 110V accessories on the "loaded" side of the house would travel through the neutral wire!  We made a temporary fix by twisting a piece of 14 gauge wire (we didn't have anything else!) around the ground wires next to the bad service drop connection and everything went normal after with 118 volts on both sides. That happened the week that construction workers were on strike here and he had to leave for 3 weeks two days later... We did notice a few things that were wrong so I think he'll need to have a few things replaced by an electrician when he gets back home!
The biggest problem with our current electrical grid isn't the fact that it's aging. My father retired from the Department of Water and Power here in Los Angeles after forty years on the job as an electrical mechanic. According to him and a number of his friends that were also electrical mechanics, a great deal of the high voltage switching equipment, relays and breakers found in distribution stations all over Los Angeles, were made in the twenties and thirties. Their designs are extremely robust and they were built to be easily repaired when a problem came up. In fact they've served so well and so reliably over their many years of service that many of the electrical mechanics have developed a great deal of respect and admiration for both the equipment and the men and women that designed and built it all those years ago. In many cases the new equipment that replaces them is of dramatically inferior quality. The biggest problem with the grid is the lack of new power generation as the population(and therefore demand) has grown. That's the primary issue that needs to be addressed. There's nothing wrong with the old equipment. It just needs routine maintenance as any new replacement equipment would.
d-jones I was wondering how the electricity situation around LA is with San Onofre being decommissioned. Are then any brownouts or blackouts because the SONGS is no longer operating in this hot weather?
<span style="font-size: large;">Well the Friedrich has bought the farm. Thanks to Consolidated Edison's voltage reduction shenanigans last night, I walked into a stifling living room this morning. I turned it off to let it cool down. Then started it up hours later, the compressor engages for about 5 seconds, starts to cool, then cycles off, and stays off. I'm pulling it out of the wall tomorrow so my dad can check and hopefully repair it.</span>
Not building power plants--funny thing. You don't notice oil companies preaching conservation. They are anxious to sell all they can come up with. Power companies don't want to invest the money to build and don't want to deal with the environmental regulations. Maybe it will be easier with the new gas-fired plants, but hydro damages the river systems and coal kills and produces ash which makes problems. So power companies are preaching conservation which is wise in certain aspects of increasing efficiency and insulating houses better, but when they are telling people to wash in cold water and almost no water, that is where their not wanting to increase generating capacity gets stupid.
Voltage reductions are when the demand is so high, rather than face a blackout, it's reduced, the least would be a brownout.....or a small amount of down time, rather than long hours of no power.....we don't like it, but sacrifices have to be made...
but this plays havock on machines, motors and electronics....
Robert
Los Angeles generates its own electricity at plants like Valley Steam out in the San Fernando Valley, so the city is seldom ever forced to buy from outside providers. L.A. was also a major backer of the Hoover Dam project and L.A. Water and Power technicians were heavily involved in its maintenance for many years. Over the years my dad spent a lot of time up there and really enjoyed exploring the dams numerous tunnels and corridors. As a result of this involvement L.A. got really good rates on power from the dam. Then we have Castaic lake which is kind of an interesting situation. The lake has an upper and lower reservoir with a dam and powerhouse. During the evening when demand is low and there's a lot of excess capacity on the local grid, water is pumped from the lower lake to the upper lake. Then during the day when demand peaks, the water is allowed to flow back to the lower lake through the turbines which generate electricity and relieve demand on the other local power plants. They've been doing this for decades and it seems to work out pretty well.
[this post was last edited: 7/19/2013-20:58]
Must Say ConEd Seems To Have Done Well By Manhattan
At least our part as there haven't been reported outages that I've heard. Cannot tell if there have been voltage reductions since the AC seems to have been working fine yesterday and today.
Texas is a sorry joke by almost any measure. But not our grid. We're 98% independent of the rest of the country, for starters. Much growth, much new equipment. Natgas turbine demand plants. Max electrical storm protection. A great deal of redundancy. Example, in 2005 a substation transformer (138kV>7.2kV) literally exploded. The one that ran my neighborhood. I heard it explode at 3 in the morning, went there and saw the fire trucks. By the time I got back home a half hour later they had wired around it and the lights were back on.
If you want good electricity, move to Texas. If you want good anything else--beside Mexican food--stay where you are.
Happening here too..
At night things are close to normal, but our electrical system is so outdated out voltage is being dropped ridiculously low during the day, due to increased demand thanks to the heat wave. This has always been an area of predominantly all electric homes, and now we are paying the price. Neighbors and family members are complaining that their kitchen stoves aren't heating as quickly, everything takes longer to cook, ( I was making mashed potatoes, and thought the water would never come to a boil), it's like cooking on a 110 volt hot plate instead of a 220 volt electric range. Microwave ovens aren't cooking as quickly either, normally a package of frozen corn cooks to perfection in 5 minutes for me. Yesterday 5 minutes merely defrosted the corn, it was still cold. Another 3 minutes got the job done. And older air conditioners are struggling to do their job, mine normally cools the living room, kitchen, hallway, and 1 bedroom. The last few days it can barely take care of the living room and kitchen.
Lake Anna in VA is an upper and lower lake generating station where they run the water between the two lakes.
Castaic was one of the towns in the path of the wall of water that flooded the valley when the St. Francis dam gave way in 1928. That was a fascinating & tragic story
Home Generators
Funny, I never considered a whole home generator as a supplement in a brown out condition. I think that is a selling point for them.
Malcolm
what is referred to as a brown out.
Luckily I never experienced one ever.
And power hasn't failed since 2003 (the big Italian black-out).
Our infrastructure is fairly efficient and voltage drop is minimal and anyways always in the range of +/- 6% and all the machines can cope with that as it's well within tolerance.
Have 100% reliable power isnt cheap
The wish for a reliable power grid comes at a huge cost.
Back in the late 90's/early 2000's, blackouts here were frequent and it wasn't unusual to lose power every time there was a bit of a storm, even in a metro area. (We live 4km from the city centre)
The government decided to put money into fixing it and the outcome as been that over a 10 year period, we've gone from paying 15c/kwh to 29.4c/kwh.
Its been a few years since we've had any sort of power outage now, but its come at an enormous cost.
The Government is now looking at what is a reasonable expectation for service continuity to look if they reduce the MTBF the costs will appreciably drop.
Brownouts are much less of an issue in 240v land as we're now rated at 230v +10% or - 6%, but the nominal supply is still 240v. It takes a pretty big brownout to drop down to the 215v that all equipment needs to be able to operate at.
Here In NYC At Least
Local power company (ConEdison) will ask large customers that have their own full or partial generating power to switch to that source during peak usage. This obviously takes the edge off demand which helps keep the lights on.
The alternative is to ask the same to lower usage by turning off a number of elevators, lights, and turning up the AC settings.
