moparwash
Tested the fill problem today and here are the results:
Water fill valve and water pressure switch contacts and wire attachments are clean and hooked up right
Machine Off - Water On = No Fill
Machine On - Water On = Fill
Machine On - Water fills contstantly and will not shut off as the water level is halfway up the window
Disconnect pressure switch hose, blow into it, water still fills
Shut machine off = Still fills with water
Unplug machine = Still fills with water
The thing I don't get is when the test is started with the machine off and water on, there is no fill, but when I shut the machine off and even unplug it, it still fills with water. I think the water valve is good but the pressure switch is bad, any ideas?
