Frigidaire 1-18 FREE
FrigidFaire
Member
Jan 4, 2026
8
1985? Frigidaire 1-18, ONE owner. Original parts including Filter-Flo attachment. Just bought a house from original owner this Summer. Has worked great for 4 months. Yesterday it decided to stop draining. Not mechanically inclined I am replacing rather than fixing.
Hate to drop off at dump when there are fans of this model. Good for parts or maybe it just needs new pump?
Your machine, unfortunately, isn't a General Motors-produced Frigidaire. It's dated after GM sold Frigidaire to WCI (White Consolidated Industries). The mechanism is different than the GM design that collectors seek. GM Frigidaire washers have an agitator that pulsates, moves vertically up-and-down. Yours oscillates back-and-forth.
Cool washer. westinghouse design probably from around 1985. "Real" 1-18s were made well into 1979 before replaced around late 1979 by this westinghouse design that is actually more 14-16 lbs effective capacity vs 18 of GM version. Bad lid lock/switch is a probable cause of no drain/spin and undersized clutch belt is something that can require attention. Build quality lower than actual GM 1-18s,but these are an M60 tank compared most current offerings.
Thank you for the info. Kinda glad it’s not the GE version since finding this one a new home would be a bit onerous.
I’ll remove the erroneous manufacture date.
Cheers for the virtual troubleshooting. I’ll give the latch a look see, however there was a slight “overheat” smell when attempting to drain. :/
I never had an issue with WCI top loaders, they seemed ok. Maybe not (nearly) the quality of a period Maytag or belt drive WP, but serviceable. Funny though, I'm not sure I've ever seen a washer or dryer that wasn't labeled "Heavy Duty" regardless of build quality. Sort of like nearly every commercial real estate agent labeling any property as "prime", even if it's a tire dump in a swamp.
Heavy Duty labeling wasn't so much a thing until probably in the 1970s. Maytag didn't label their machines as such until other brands began doing so. Customers wondered why Maytags aren't heavy duty so dealers were sent adhesive stickers to apply to the consoles. Tada, Maytags were then Heavy Duty!
Although if you left a few screws out of the dryer back or stripped a few, it tilted over and the drum rubbed the inside of the cabinet. I think they bought sheet metal From Gillette that didn't meet spec for razor blades...
Located in Warm Springs VA.View attachment 322555View attachment 322556
If this is still available, I would be interested. I live in S. W. PA. I would not be able to pick up until 1/23. Thank You
The curved agitator vanes is a detail that makes me think this washer is a few years into Westinghouse "1-18" design-I am used to 3 straight vanes on this era of WCI westy, but could be wrong on that. The burning odor noticed could be the lid lock solenoid coil burning up-In that case washer will just stop when time to drain/spin. If there was a hum and slightly dimmed lights then click of motor overload protector tripping off,probably a timer problem. dziner: go get it and give full report ! :)
Great! We will be out of town. Give me a day or 2 to check if one of my neighbours would be willing to assist.
Good news. I toyed around with the lid lock and got the beginning of motion from spin cycle. Basically stuck my finger under hood blindly moving parts around hoping not to get a pinch or a jolt (strongly underscoring my lack of mechanical aptitude and willingness/dumbness to risk body parts).
Anyone have a recommendation on new a top loading large capacity washer that is primarily analog (less computer/electronics & more mechanical=easier repairs and longer lasting imho)
I’ve seen a lot of positives for Speed Queen and GE Profile 5 (currently on sale)
Those have computer boards behind any rotary knobs that may be on the panel. (Speed Queen still produces a true mechanical control machine, TV2000WN, but it's considered a commercial-type unit.)
Hi Dziner
Funnily enough the friend that will rendezvous with you on the 23rd to pick up the washer just got back from Pennsylvania and that is where you live. Small world.
*edit* I DM’d you with contact info.
Glad this beauty is being re homed. Frigidaire looks great and with a little know how will be back to washing loads again. Yay.
My great aunt had his model and it was rather decent I thought. That agitator was called HydoSurge and gave a decent rollover action despite the jerking wash basket action. Her machine was located in St Pete here in FL when she lived here as a snowbird...so that washer did not have heavy usage year round. I didn't care for the locking lid for spin and extraction was ok ...no worse than a Whirlpool built belt drive in that era.
