Warm Rinse Suds
Chetlaham
Mar 11, 2013
5,294
United States
Does warm rinsing produce more suds or is it simply that much more effective at getting out detergent? I know I asked about warm rinsing extracting more detergent and the general consensus was yes, however I noticed when a comparable load is rinsed on warm, there are more suds and they are thicker. Is that much more detergent being extracted or does warm water in general produce more suds?  If the difference really is that stark in detergent removal, I will start doing more warm rinsing.
warm rinse
I use it all the time. I think its very effective, but many will disagree. I think the reason you are seeing more suds is become the water is able to break down the detergent better. I'm not sure a warm rinse may be effective in the summer months, but it definitely is here in the midwest when the incoming tap water is around 40F.
Most modern washers don't offer warm rinsing anymore because it will ding the energy ratings.
Warm deep rinse, spray rinse, or both?
I use the warm rinse option for all warm and hot items in the 806. These machine also spray rinse with warm water, like God intended. To go even further, having a tempering valve increases my temps to a solid 120F warm wash/rinse and higher volume of water (cold + hot for temper valve + hot again directly to the water valve). Warmer temps plus an increase in water volume for the spray rinse does wonders for great rinsing. During the winter months when water temps are lower, an increase in hot water volume to the temper in order retain 120F provides even better spray rinsing. It's good entrainment for the colder season.
Have you glanced at the wiring of the SQ to see if you can manipulate a warm spray rinse out of it? That would be a fun project that shouldn't cost much, if anything at all. Also drilling out the restrictor on the hot side of the water valve for a true 50/50 mix will at least fill the tub quicker.
Warm spray and rinse would be ideal. I've thought about manipulating the SQ wiring but at this point I don't want to alter the machine from its original state just for the sake of enjoying an as-is once new out of the box Speed Queen. I remember Sears had a warm wash cold rinse only Galaxy- it would have so cool if the model was warm wash warm rinse with two wires down to the water valves splitting the same way they did on double solenoid Kitchen-Aids and Maytags. Pressure switch directly in series. But sadly the energy regs have gone to far. I remember the tech sheets even went as far as saying "Denotes Energy Efficient Components. Do Not Substitute." Talk about authoritarian.
If you have a wiring diagram of the SQ, take a good up close picture of it and post it here. We may find a quick, non-intrusive work around for a warm spray rinse.
How are you achieving a warm rinse???
According to the chart, all deep rinses are cold. Are you using the wash cycle to warm rinse?
What I would do is add a simple relay that its switching coil is energized whenever the cold water solenoid is energized. Then have the relay send power to the hot water solenoid whenever its switching coil is energized, this way you'd have automatic warm rinses. You could add a toggle switch to the back of the control panel to turn this feature off for the times you do want cold rinses.
I use these inexpensive relays all the time.[this post was last edited: 7/7/2024-18:53]
Yes. My rinse cycles look sudsier than the main wash. Warm helps to loosen to fabrics and has the ability to get all the detergent out better, as where cold stiffens the fabrics which is why on cold rinses you don’t get many suds.
I'm not seeing an easy workaround with that setup. Unimatics advise implementing relays is probably the best approach.
So I've received a couple of requests by email about how exactly to wire a relay into this Speed Queen washer to achieve warm deep and spray rinses. I created a simple schematic using the SQ wiring diagram.
In order to do this you'll need to know how to do the following, if you're not sure there are a ton of YouTube videos on how perform these tasks...
#1 Cut wires and strip about 1/2" of insulation from cut wires.
#2 Join 2 or 3 wires together with a wire nut.
#3 Crimp uninsulated quick disconnect wire connections to put wires onto relay terminals.
#3 Drill 2 small holes in cabinet rear to securely mount relay near the water mixing valve. You can use 2 small screws, lock washers and nuts.
You'll need to buy 16 or 14 gauge wire to make the connections to the relay.
It also goes without saying UNPLUG the washer before attempting to do any modifications!
This first example is how to do this without the optional toggle switch to turn this feature on and off. Some may want to add a toggle switch to turn this feature off so you get a cold rinse during the summer months. The summer is the only time I ever use an occasional cold rinse and that's only if I've done warm wash, hot washes always get warm rinses in my house.
Robert, you know me so well! The temptation to do this is now overpowering. I can't thank you enough- you're smarter than me in that you've figured out a simple yet effective way to achieve a warm rinse with the option to turn it off during the summer months. Much thanks!
A resounding Mahalo!
to you Robert for sharing your resourcefulness with this forum.
Here in Hawaii, we are blessed with enough sun exposure where solar hot water heating (as well as PV) systems are a no-brainer.
As a result I always do laundry in warm water and, fabric permitting, hot water, these temperatures seem to work best with the Persil pods I use.
Additionally, a warm water rinse seems to remove detergent residue better than cold, a feature my old Maytag had, and, hopefully my Speed Queen soon will.
You layout is more flexible and automatic for but for those who are nervous around electricity and want a simpler workaround that doesn't hack up the original wiring too much, this may be the way to go. Just have to remember to switch the water temp to warm if washing in hot although there's nothing wrong with a hot spray and deep rinse in my opinion. Most don't have their water heater turned up past 120F so it's really on the warm side, anyway.
120F
Bob, I can't wait to perform the modification you outlined on my SQ top loader, I'm waiting on the relay to arrive from amazon.com
I've solar hot water heating for my home, on a typical sunny, summer day the tank water temperature will get up to 140F by 4-5 pm.
Yes, I did remove the tempering valve which used to maintain 120F tank water temperature and my family is well aware of the temperature of the hot water, here in Hawaii we normally shower in the evenings, by 8 pm the tank water temperature is about 130F.
My 120 gallon solar hot water tank has a timer which is set to run the heating elements only in the mornings, even then, the thermostat on the heater is set to 120F.
With such an abundance of hot water in the afternoon, we'll normally do laundry then with warm water and still have an adequate supply of hot water for evening showers. Laundry requiring hot water wash (such as whites) are done at this same time period.
The only drawback to this setup is we can't hang our laundry out to dry at that time of day for effective drying, a practice which is a no-brainer in Hawaii, so in the dryer it goes.
My 30 panel PV system with battery backup provides more than adequate energy to power the dryer.
Indeed, I love my monthly electric bill of just $15[this post was last edited: 7/13/2024-13:32]
Warm rinse
It absolutely rinses better. I have been trying to run a hose from a sink into the Kenmore’s dispenser during the final rinse. The warm water dissolves and breaks down detergent residue much better. I feel like the difference on towels is noticeable.
Energy regs killed laundry. Warm rinse makes sense in the winter where around here the water is close to freezing. If I wanted chilled rinse water I'd be calling for a heat pump in all washers.
