washerfetish
Active member
- Joined
- May 5, 2012
- Messages
- 38
My front load washer drain hose makes gurgling sounds as the washer goes through its normal washing cycle. as the washer works I keep hearing these gurgling sounds as the washer is working normally. Is it normal to hear gurgling sounds from the drain hose? It sounds like water is sloshing around in the drain hose. Did I hand the drain hose properly when I got this washer a couple of weeks ago? Is there a better way to hang the drain hose?
Thanks a lot.
Thanks a lot.
