Washer & Dryer Saved From Scrap In NJ
1990 Whirlpool set
My aunt and uncle had the same 1990 set (I think Combo52 meant 1990) until a few years ago. They performed well and never required any repairs. They were stored in a damp basement and rust eventually killed the washer. They replaced them with a new DD set (2007?)
I have that exact dryer model
also in gas. It came with the house I purchased. It's only needed one repair. (The felt around the drum bunched up, belt burnt up of course). It's a great dryer. You'll love it.
Excellent pick up!
Glad those machines had a sudden change of planned location :)
As for that slowdown in the wash, I usually just set the timer to Heavy all the time in the regular cycle, and I guess why it doesn't bother me too much is that by the point it slows, I'm sure most of the dirt and other things have already been removed by that point.
My Whirlpool set
I bought a Whirlpool washer and dryer matching set in 2002 that is probably the same inside as this set. I have not repaired anything on either machine. The only thing I have done is when I moved to a house that did not have gas piped to it, I converted the dryer to propane and I'm running it on 5 gallon tanks. I am hoping the neutral drain parts in the transmission last at least until most of the projects around the house are done. OOPS! I just remembered a repair. I replaced the dogs in the agitator. The top part would not turn when clothes were in it. You got an excellent find. By the way, I have hauled appliances in my '84 Chevy Citation hatch back, including a 30" wide stove.
Bo-Caa   Bo-caa  Bo-caa ....
Brian Congrats on the pair DD are the new vintage.
Hope to see them up and running soon.
Nice !
Darren k
Hey Garyl, at least I don't feel so bad now. How the heck you fit that stuff in there I will never know lol.
John - 36 positions is infinite enough to me lol. Why were these the most produced? Popular with consumers?
Hey Martin, if you wouldn't mind, a few pics might tide me over till I come down and see for real.
Darren-Thank you, I hope to get them downstairs tonight after I'm finished arranging, and then give them a good run.
Hi
Nice looking Whirlpool set. My Grandma had a set very similar to this except that it was a little higher up the line. Can anyone help me identify the model? It had a bunch of push buttons in the middle for the temp selection and it had an "infinite" water level selector. It also had a tan tub
That almost sounds like my Whirpool Supreme from the 80's. It has 4 rectangular buttons in the middle, and my water level selector is infinite. Does it have a salmon pink color around the timer dial that you recall? Not sure about that tan tub though.
Idk maybe the tub was white, I just know it wasnt dark like the speckled one here. About the timer, pretty sure it was just like the design shown.
I used to be fascinated with this washer when I was very little. One of the things that made me wonder the most was how the washer would start spinning after I opened and closed the lid in drain. At the time, I could not figure out why the washer would change its cycle for me : )
Jed -
What you're describing sounds like a machine I have that someone at work thought I'd want. I'll try to get you a picture in the next couple days.
The tan tub though....this one's tub is discolored, though I would not call it tan. They started out white. Was your grandmother's home on iron-rich water?
Gordon
iron-rich water?
I wouldn't be sure exactly, they machines were used on a farm in South Dakota though. I dont know if that type of water may have changed the color of the tub.
Why the set was dumped...
I have two theories. I ran the washer tonight and it leaks a decent amount and the agitator dogs are not functioning. Perhaps the leaking was from sitting outside in freezing weather and maybe the agitator dogs might be backwards, but anything is a possibility I guess.
If you hold the corkscrew of the agitator, it sort of rocks a little. If you leave it be, it free spins. Is it possible the dogs are backwards? I could not figure out how to get the agitator off. If I pull on the skirt, I manage to lift the whole basket.
AGITATOR DRIVE DOGS ON DD WASHERS
Brain funny that you should say they might be in backwards, while they can not be installed backwards they can be turned upside down and that will actually make them work again for a while. But basically they are simply worn out and should be replaced.
As to why these machines were replaced who knows for sure, but 22 years in these affluent times is a long time for many people to keep a washer and dryer. In many countries such as Japan they often replace major appliances in just a few years. Americans are among the most practicable people in the world when it comes to the length of time that we keep cars and major appliances.
Thanks John, I will definitely try that and see what becomes of the corkscrew. Is there a special way to get the agitator off, or is it just stuck on really good. I cannot see how to change the agitator dogs easily. Are there service manuals on these?
Seems easy enough...
I just bough the FSP 285811 kit from online for $6.80. It comes with the cam, dogs, cam cover, and some rubber seal. When I get those in, hopefully before the weekend, I can get them in the washer. In the meanwhile, I guess I will try and find where that leak is coming from and get the dryer hooked up tonight.
I have videos I will be uploading shortly so you can see what I am talking about and let me know if there is any unusual infomartion.
Thank you for the video link Gordon, for some reason I didn't even think YouTube. Duh on my part I guess lol.
Good catch, Brian! I wonder if the wash action is going to be more shredding than my KitchenAids!
Coincidentally, if you are tired of the Tag gas dryer, I have a home for it - its nearly a match to the one Martin gave me for Jim's mom.
without hi-jacking the thread....this is for Brian....as my basement is in the finishing stages.....the plumbing is what I want you to focus on......I have the Hot/Cold water lines running parallel across the walls, and just tap into them with "T"'s for each station........the drain is only 1 1/2 inch, but I can spin all the machines at one time, and have a small amount backup into the laundry tub, as overflo protection.....not that they ever would all run at the same time...but good to know I could...I will start a new thread of both rooms....
More findings...
The leak from the washer is from the water pump. It must have been for a while because there is rust scars. It looks like the rust made it to the motor but it appears ok. The agitator dogs are completely worn, so when that kit comes, I will get the new ones in.
The dryer was making a weird thumping sound and did not feel quite right. Turns out the felt tore and bunched up a little. I took the whole machine apart and found a lot of lint and dog hair? inside. Pics to follow soon.
Overall, after the washer gets its new pump and agitator kit, and the dryer gets a new felt seal, and probably a new belt would be a good call, they should both be good as new.
Eric - I was thinking that, because as much as I would love 3 dryers, I just do not have the space or proper hookups to do 3. Plus I think Matt would not like it so much if I forked over 3 dryer loads at once. If someone needs it, unlike me who has others, than I would prefer they have it.
1990 WP WASHER AND DRYER PROGRESS
Brain glad you figured out the washers leak, the pump is usually the only place that a DD washer leaks as it was a pretty well designed machine.
Dave the hose clamps on the water pump hoses are the spring type and is no way to tighten them as they are self tightening. I have never seen a leak on the hose connections on these machines.
Brain if you are going to change the belt on the dryer be sure you get the wider 5 rib belt as it is much stronger and will not slip and squeal when the dryer is started with a heavy wet load. The part # of the heavier belt is 349533, WP does not sell it any longer but it is widely available from after market suppliers, it is the only belt we use when servicing these 29" dryers.
I have the similar electronic set. They are very reliable. The dryer has never had a repair, ever! And they dry your clothes without baking them. I purchased the set new in Feb of 1993. The washer agitator dogs are VERY easy to replace. It took me 15 minutes to do the job.
The only thing about the dryer is that WP recommends in the owners manual that every three years you pop the cover on the dryer and remove all the lint. They do collect lint! But after you clean the dryer they dry so fast.
If these machines were built in 2000, wouldn't they only be 12 years old? They are just now being broken in. And since so many were made, I think parts will be easy to find for them for the next 30 years or so.
1990 WP DD WASHER AND DRYER PAIR
Sorry about my earlier mistake on the age of these machines, as others correctly pointed out they are 1990 not 2000, I guess that I was thinking about [ design 2000 ] which is what WP called the DD washer when it was introduced. Does anyone know what Sears called the DD Kenmore versions?, I am sure Gordon does LOL.
Hey John & Martin...
John - Thanks again for the info. If the wide-belts are better, why did they go to those skinny belts? It definitely looks like the pulley was designed for the wider one in the first place. A skinny one was on it when I took it apart. I wound up putting a skinny one on my 80's Kenmore. So far so good, and I know I've put some heavy loads in there before.
What's the the need for the drum bearing kit FSP 279441 when you have the felt seal FSP 3406129? I always assumed the felt was rubbing on the lip of the cabinet.
On the washer, would my cabinet come off similar to what I saw on an online video where the console is titled back and there is these 2 clips to slip off underneath? I tilted the machine back last night, and saw the pump in the front, but it didn't look to easily accessible.
Martin - Nice Speed Queens! I love that avocado one.
Belt Change & Cabinet Removal
My only guess that those skinny belts were made was that they were cheaper to make.
As for removing your cabinet, all DDs are done exactly that way. What's nice about the older machines (including yours) is that the screws are on the front of the control panel, so it makes the job a little easier.
@combo52: yeah, that's what I had meant about the hose clamps. But that's my fault though, several times I keep forgetting to explain what I mean, heh.
Excellent! would be great to hear or possibly see how the progress goes!
Heh, it may be a while before I can start visiting places for collections, but anything can happen in the future ;)
More pics...
I took the washer out to swap the pump and here is what I found. Top plastic ring already taken off by the way. Separate pics of it not taken yet.[this post was last edited: 1/31/2012-08:50]
