Hey everyone I have a 1979 GE washer and dryer set I bought for $25 each 8 years ago and the washer needed a new water inlet valve. While I had the back cover off I sprayed the belt with belt dressing and put a shot of WD-40 on a few moving parts. A few weeks go by and we did a load of whites only to find that some of the clothes has speckles of dark grease. I lifted the agitator off and saw the top of the shaft has some oil on it and wasn’t sure if that was normal. I’m guessing the WD-40 either worked it’s way up the shaft or water is getting into the shaft forcing oil out.
