washing machine controlled by square plastic card
tunde
Sep 24, 2020
0
glasgow
I think it was in the 70's or could be 80's we had a machine which had a square card with grooves in each edge and you selected the cycle by pushing the card into the machine. We used to say it was computer controlled but maybe it was more like a mechanical punched card device. Anyway cant remember the name or when it came out, does anyone know the machine and have any pictures?
Thanks
Hello, please see this tread...
...UK market front & top loaders 195? to 1990 - theories, queries & rarities
I posted a brochure on the first Hoover Keymatics yesterday, which is perhaps the machine you mean. Bosch did one too, but in the UK this Hoover one was the most prevalent.
Hope this helps.
Cheers, Alan
Hi Tunde.
Welcome to the forum.
I don't think the UK market ever received the Bosch keyplate controlled model so, on that assumption, your old machine will have been a Hoover Keymatic for sure. Question is, which one?
There were a number of models, across a number of different ranges and sold new from 1961 through to 1982.
I was going to post a link to an old thread detailing all Hoover models made over 30 years from 1961 to 1991, but that would be a bit cruel making you trawl through all that (let me know if you do want to look through the thread and I will post the link separately).
To simplify your search, I have posted images of all the Keymatic models that Hoover made and sold in the UK. It should be one of the following models (note that the photos are posted in the order they appear in the list below):
3224
3226 ... these were slant fronted machines, with angled drums and an impellar at the back of the drum
3203
3203H (models 3203 and 3203H were visually identical)
3223H ... these models were built with a wider than usual bodyshell
3243H version 1
3243H version 2 (version 2 had colour changes over version 1)
A3050 ... these three models were from the 'Matchbox' range, the A3050, being an exclusive model, only available to buy at Electricity Board Shops
A3008 ... this was from the 'Superstyle' range
A3062 ... this was from the 'New Magic' range
& finally
A3112 ... this was from the 'Smoother Hoover' range
Let us know if your machine appears then, if we have more images, we can post some for you.
Unless you had an A3050, then the likelihood is that an example of your machine is preserved in someone's collection.
Regards
Paul
Hi Jon.
I remember you mentioning on a past thread about the Keymatic you used on the Isle of Wight.
Attached is the brochure from 1981 - enjoy!
Regards
Paul
Hoover Keymatics
We have just renovated the 2nd style of Hoover Keymatic, the wide bodied Hoover Keymatic 3203 of Als, which was originally found at a household recycling tip by our friend Gary (Electron1100)
Heres the video:
And the link to the thread on it here.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?79543
Hoover Keymatic Isle of Wight
Hi Jon Jetcone, really glad you have found the model keymatic you used in the Isle of Wight all those years ago...just got there in time as it was the last one produced, promoted as "New fabrics, New Keyplate for Programme Action,
never quite worked out like that, the first model alone had 4 timer upgrades along with 6 harness changes !!
Now we're summing up other machines than the Keymatic, I think the Swiss Schulthess Super 4 has to be mentioned here. It works with cards that slowly are pulled through the card reader, it works like a timer. Every programme has it's own card. The card on the right shows the number 25a, so a lot of cards. must have been available.
Great pictures
thanks Louis for the info on those machines, never saw them before.
thanks Mike for posting those great videos and pics of the Keymatics (mine is sadly now under the stairs awaiting a big repair...) btw still have that heater for you ;-)
Cheers, Alan
Paul
a big thank you for the brochure! Mike fun to now see it was the 1100 as I had remembered a chrome ring around the window but no chrome square door so I was confused. What cool machines. Louis I hope  you find a Schulthess ( skuthis??) machine those cards are pretty cool tool.
Gotta get this covid thing behind us I need a UK Wash IN again !!!
On commercial/industrial side of things many washers in 1950's through 1970's (IIRC) if not later used some sort of card system as "automatic" programming.
Computers/electronics were just coming into their own and trickling down into all sorts. Those old enough or maybe otherwise will remember when punch cards were used to program computers.
Programming if you will via a punched "card" had been around for a good hundred years or so. It was how looms were "programmed" to create embroidery and other design patterns on fabric.
https://en.wikipedia.org/wiki/Punched_card
Mirroring Alan's thanks
Thanks to Louis and Chris from me also, for posting the Schulthess images.
Never see that system before - quite an eye opener and a new variation for me on the traditional keyplate system.
Bosch also did a keyplate controlled twin tub too. Did any other manufacturers go down the keyplate road for their domestic machine offerings?
Paul
